  1. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    A while back you guys had a conversation about octane.
    This weekend I tried some C-12 ( 108 octane) fuel for a bog race.
    What a noticable difffence.
    The response time on the engine was a lot quicker . I could rev to 6000 rpm on a dime.
    The pit was 200 feet long. Used four gallons of this stuff to do 4 runs. At the end of the last run I freaking ran out of gas.
    It just sucked it up.
    I would not reccomend it for wheeling :)
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  2. chevyboy24598
    chevyboy24598 1/2 ton status
    Jul 17, 2001
    212
    Va, USA
    I run 106, my 350 won't run on anything else NOW! :(
    <a target="_blank" href=http://www.pinelanemuddbogg.com> pinelane </a>
    <a target="_blank" href=http://www.bodatious.com> bodatious </a>
    <a target="_blank" href=http://www.mudboggingfun.homestead.com> my site </a>
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    heh heh... uh oh... Now you're addicted. Time to step up w/ the big boys and run the 110 or worse yet get into the 116 leaded [​IMG], but for the rate the beasts who drink this stuff go... the $5-$10 a gallon price is killer!
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  4. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> I have to run the highest grade of pump gas with my new motor.
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  5. white_knight
    Feb 23, 2001
    1,171
    Yeah, I like it! I think next time I'll try one notch higher.
    4 gallons for 800 feet. Ouch. It cost me $65.00 canadian for that.
    nia.com
    </a>
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Now that is some bad gas milage.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If I remeber right;
    A top fuel digger burns up something like 5 or 6 gallons in a 1/4 mile pass!
    If someone was to kick over a 5 gallon bucket, it would still be pooring out by the time a draggster poped the chutes.
    Now, thats poor gas milage! Gawd forbid the EPA should get wind of it!
    Twiztid
  8. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    just dont use airplane gas had brain fart cant rmeber the name for it but ive blown 6 snowmobiles, 3 motorbikes, seen a boat and truck both burn down from it i guess it burns differntly then normal gas any body with planes wnt ot explane on the differnts?
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
  9. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    On the airplane fuel. I used to work at the local airport pumping gas. I don't remember what the diffrence was. But I was told not to exceed 50% in a tank. I used to put it in my dads j**p. He had a custom 30 gallon tank that ran under both front seats. I would go down to the 76 station and fill it up half way then go back to airport and fill the rest with 116 octane. My dad never did now I was doing it. He couldn't figure out wy sometimes it ran so much better. Back then he had a pumped up 350 in it. Know he has a 283 with a edelbrock efi. If I ever own a J**P again it will be that one. Has for the 110 octane now. I use it in my gokarts it cost $6.50 a gallon but man it is a world of diffrence in a one cylinder motor.......Dan
    Sorry so long. It brought up some old funny memerios......
    If it ain't broke.......Don't fix it....
  10. bandit
    Mar 4, 2001
    690
    yea i always ran %50 too did make it run super good but then aging when you open the hood of snowmobile to cool it down after a grass drag and you see your piston thoguth your head you understand what that burning smell was =-) thats funning about your dads jeep
    AJ
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have done a few of those on my gokarts. We call them windows. When the rod is thrown threw the block. We all had to go to metal seats after one almost made it threw a fiberglass seat.............Dan
  12. bandit
    Mar 4, 2001
    690
    never broke a rod just burnt heads adn the cylder walls burnt out once but form what iunder stand is the airpalne fuel runs hotter then regualer gas plus a running a snowmobile on grass in the heat isnt good anyways so..... i guess i had the bad of both thats prett scaring to think ofa rod going thought a seat like that
    AJ
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    It gave new meaning to a rod up your butt.........LOL
  14. bandit
    Mar 4, 2001
    690
    LOL
    AJ
  15. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you have a built motor, especially one with high compression ratio, then higher octance can help. On the other hand, higher octane generally will not make any difference in a well running/tuned mild stock motor.
    Contrary to popular believe, the octane rating is not a measure of how much "power" is stored in gasoline. Rather it is kind of a basis for the flash point. For example, if you are running something like a 10:1 or 11:1 compression and try to run regular 87 octane you will get "pinging" or detonation. This is caused by the fuel/air mixture exploding (due to being compressed too much) before the plugs fire. The higher octane rating means the fuel is harder to burn, meaning that it can be compressed much more without exploding.
  16. dyeager535
    26,982
    191
    Not only that, I believe I have a link to a car mag write up (with dyno tests) that stated running octane higher than the motor needed, hurts power. I'm betting it has something to do with the higher octane=slower "burn" thus, with high compression, the cylinder temp is already higher, so it burns fine.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  17. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That makes since. My dads 350 was pumped up a bit. To much. He went threw a lot of drive lines and axeles. That is wy he took it out and put it in my brothers camero. Then he went with a almost stock 283 and just 2 years ago put the EFI on it. That thing sure did run good on the higher octane.......Dan
