Odd Engine troubles?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nau81blazer, Jun 8, 2005.
  1. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Hello all,
    So I was driving blazer yesterday and about 5 minutes after I started it, it started to slightly miss, and then a little worse, and then it was running pretty bad, then it was barely running. Real dark black smoke, it will start but i have to stay on the gas a bit the whole time and it still misses really bad. Odd thing is it gradually happened within 15 minutes. Anyone heard of this? I check the distributor hold down to see if it was loose and the dist. was moving around. It was tight down though. I assume a carb. problem cause of the black smoke. Any ideas of where to keep looking would be greatly appreciated. Thanks for the help guys! :D
    --Adam
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Black smoke means too rich, check for a bad choke. The choke plate should be wide open when the engine is warmed up to operating temps.
  3. kd7kmp
    kd7kmp Registered Member
    Jun 2, 2004
    99
    Springivlle, Utah
    It sounds like 4X4HIGH is right on. Your choke may be stuck closed.
    Kevin
  4. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    Cool, thanks guys! :thumb:
    --Adam
