Odd Flywheel question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaveBlazin, Oct 11, 2002.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Well this may sound odd but if my flywheel was loose what would it sound like. Cause I got this weird clankin sound coming from the bellhousing area. Im pretty sure thats were its coming from and occasionally it will make other farm animal noise's......
  2. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Is it a constant clanking sound, even at idle? If so, climb underneath when it's idling and check it out. You could also remove the dust cover and see for yourself if it's loose. If it is loose enough to be making clanging noises, I wouldn't drive it another mile.
    The noise you are hearing is most likely something else. Maybe a rock or a bolt/nut got stuck up in there?
    Do you have any shifting problems? Could your tranni be going out?
    Thomas.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Are you sure it's from the bellhousing area not the bottom end of the engine?
    Also is it just noise or do you feel anything wrong, like slipping or rocking, is it only when you're driving it or also at Idle?
  4. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Is it a manual flywheel or a flexplate (automatic)? I've had a couple automatic flexplates crack and make some pretty loud rattling/clanking noises before.
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    BAH! I bet its the flexplate bolts that connect the torque convertor to the flexplate. I'll put $ on it... my 400 used to loosen these bolts all the time. Take em out one at a time, and reinstall them with a little red locktite on them. /forums/images/graemlins/thumb.gif
    Just my .02
    -Dan
  6. dyeager535
    26,982
    191
    I wonder if anyone glanced at your signature? /forums/images/graemlins/wink.gif
  7. mountainexplorer
    Nov 14, 2001
    4,903
    Oops, stupid me. I even checked your profile and didnt even see the SM465 in the signature. Could be a problem in the pressure plate/throwout bearing maybe.
  8. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    SMART @SS! /forums/images/graemlins/thumb.gif k... well... forget what I said then! Does the noise go away if you depress the clutch?
    -Dan
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I did /forums/images/graemlins/grin.gif
    The first thing I thought of was the flexplate crack but I looked at his sig and found the 465.
