ODD gear ratio's........have you ran them or can I get them?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Jun 21, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    ODD gear ratio\'s........have you ran them or can I get them?
    I am running 3:73's with 33's and with the new tires I'm about to install,( 35's ), I want lower gears. I drive it daily and with a th350, 456's will be a little low so has anyone ran a 4:27 or 4:33 ratio in there rigs? And is it available in an X-gear for the smaller carriers I have?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: ODD gear ratio\'s........have you ran them or can I get them?
    You'll only find odd ratios in odd axles. I had a '62 Willys Overland Wagon with some odd-ball Dana axles that had 4.27 gears. But for our stuff you'll only find 3.73, 4.10, 4.56 in the range that you're looking at. /forums/images/icons/frown.gif
  3. twenty_below0
    May 16, 2001
    436
    So no such luck with Randy's Ring&Pinion, or another specialty shop huh........well shoot. Any one run 35's or 36's with 4:56 ? Could you give me your RPM's at 55mph with a TH350 , see how harsh it would be to run them.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My '87 has 4.10s and 31" tires and I drive it every day.
  5. twenty_below0
    May 16, 2001
    436
    I would think that 4:56's and 35's would be a little lower.....but maybe not? Guess I will have to find out this summer,..... might just have to go to 37's next year.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Should be about 2550 RPM @ 55 mph with 35's and 4.56's. That's with a true 35" tire diameter...
    Thats a liveable RPM...but I never drive just 55. At 65 it would be turning 3000 RPM...
    Rene
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I dont think your SOP meter would notice the difference between 4.33 and 4.56 enough to justify the cost/hassle factor
