Odd grill swap
Discussion in 'The Garage' started by bear76, Jan 12, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I have an 83' m1009 with the headlights over the driving/turn signal light. I perfer the look of the stacked dual headlight. (NOT the 91' style) Is the rad. support the same making the switch easy?
  2. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I dont know about the rad support but u mean like this?
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    from what i understand you are saying, you have a single headlight setup now. if that is the case, the core support is different fo the stacked headlight, as a matter of fact, all different headlight combo's are different core supports.
  4. bear76
    Oct 16, 2005
    1,065
    here
  5. Grim-Reaper
    7,385
    Atlanta
    I'd stick with the singles. You can get a really kick ass set of H4 head lights for the single. The double (quad lights) bring the suck. Not good aftermarket lights available. Too small of reflectors.
    Mine sucked so bad even after the best sylvania's Had HALF the range of the Hella H4's in my 4Runner and my wife's sealed beam in her Honda are still better. I could out drive the lights on dark back roads at 55mph. I ended up putting some Hella Ralley 1000's and wired them to come on with the high beams to solve the problem.
