Odd SAS questions
Discussion in 'The Garage' started by the beast, Jun 16, 2005.
  1. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Since I got no response in the IFS forum, I'll try it here.
    I've got a 98 Tahoe that I'll be doing a SAS on. Of course it currently has the NP246 AutoTrac t-case. I know that it's not supposed to be used for a solid axle truck, but why CAN'T I use it? Is it just because the all wheel drive won't work or is there another reason. I've never used the AutoTrac feature as it is now. I don't see myself using it in the future.
    Also has anyone ever done an SAS but used coil springs instead of leafs? Not coil over shocks mind you, just regular coil springs. I know the ORD Blazer was coil over shocks for a while, but I was looking for a more conventional set-up.
    Thanks for your help.
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Have you tried posting over at Pirate4x4.com, be careful though, this isn't a newbie question, but don't ask any over there. They can smell fear over there.
  3. the beast
    Oct 15, 2003
    535
    Providence, RI
    No, I try to avoid POR like the plague for that exact reason. But I'll give it a shot I guess.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I know I saw where someone used coils once, I just can't remember. It's not a rare thing though.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Plenty of people have done it. Of course you need a four link, and those aren't cheap nor are they just a bolt in thing. To setup coil springs with a four link will take a good bit of knowledge(to do well and right). Read on Pirate and the four link threads in The Center of Gravity(part of the Forum here).
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I dont see why you cant use that T case. Im sure the Autotrac senses wheel slippage with the front ABS sensors, which will obviously become INOP. once you put a soild axle in it. Therefore it will work just like a normal electric shift case, like the NP243. I know theres somethign special with the driveshaft with those cases too.
