OEM engine crossmember brace (85-91 str8 axle 4 x 4)
Discussion in 'The Garage' started by TheEmissary, Feb 1, 2006.
  1. TheEmissary
    TheEmissary Registered Member
    Apr 15, 2000
    63
    Houston, Texas
    Does anyone have a crossmember reinforcement brace which will fit 85-91 straight axle 4 x 4s - a publication which I came across lists the original GM part # which has been discontinued since 1998.
    The brace is actually an L-shaped stamping about 1/8" or 3/16" thick; it uses two bolts that attach to the RH engine mounting pad/biscuit assembly (the OEM installation which I have seen in a salvage yard is held with 2 extra rivets).
    I am in need of this part ASAP - if anyone has the GM part #; I can look it up through PartsVoice.com.
    The crossmember assembly that I am referring to is a 1/8" thick plate forward of the motor mount towers. I can upgrade to the Colorado off road engine crossmember; as of this writing, I do not have the $200 because I am on a fixed income.
  2. dyeager535
    26,981
    Just out of curiosity sake, any reason you don't just get the crossmember itself out of the wrecking yard?
    Mine ('81) was cracked, so I just found a newer one in the wrecking yard and paid $20 for it. Along with a bit of elbow grease removing the rivets.
    I can't believe the piece you are asking about is going to come in at less than what you can buy the whole crossmember for, used.
