OEM-Style Door Mirrors
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by daveo, Jul 12, 2002.
  1. daveo
    daveo Registered Member
    Mar 19, 2002
    11
    Masonville, CO USA
    I recently purchased and installed a set of the OEM-style door mirrors on my '71 from one of the major aftermarket suppliers. They are the standard chrome - short arm bracket - square head.
    [image]http://coloradok5.com/gallery/albuq21/aaf[/image]
    After a few weeks of minor wheeling, the mirror heads fell off the arm brackets. This happened on both doors - I hit nothing - the cause was purely vibration and bouncing. The mirror heads attach to the bracket via a slotted, tapered, press-fit. There are no screws/bolts.
    Has anyone experienced this problem? Has anyone had better luck w/other mirrors that have the same 3-hole screw pattern to mount to the door? Is there a major difference between "OEM" mirrors and "Reproduction" mirrors?
    Any help would be much appreciated.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    hmmm I too replaced mine quite a few yrs ago but have not had that issue. I actually broke the glass out of one of mine but the frame/arm stayed right were it was supose to. Do you have that black washer/grommet that goes inbetween the mirror and sheetmetal? Duno if that would cure it or not? maby you got a lemon set? I think I paid like 35bucks each, I think the OEM are like 55each. So I assume I have the aftermarket type?
    Good Luck
  3. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Wow, bummer. I've had a new set of aftermarkets like that for six months or so and no problems. I agree, I think you got some lemons. I'd try to take em back.
  4. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    I too had bought a aftermarket mirror for driver's side. It lasted all of three days before falling off on the highway, spent the extra bucks and bought OEM and its been fine for 6 years now. IMHO the aftermarket ones are shite, spend the dough on original.
  5. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    I had the same problem. Maybe 6mo.
  6. daveo
    Mar 19, 2002
    11
    Masonville, CO USA
    Thanks for the input. Sounds like I'm not the only sap whose had problems with crap parts. I do have the black plastic "spacer" between the door and the mirror bracket. I'm going to try complaining to the supplier, and see what happens. Worst case, spend some extra cash for the OEM replacements.
  7. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    I got mirrors off of a '96 ford F-150 for my blazer. they are much bigger than stock mirrors but still bolt on in the same place (with some minor mods to the door and mirror). also they are breakaway mirrors. they come in black or chrome and look great. e-mail me if you'd like a pic of them.
