# of teeth on ring gear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Toledo, Aug 12, 2002.
  1. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    If a D60 has 41 ring gear teeth then what gear ratio is that?
  2. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    you also have to count the teeth on the pinion.
    mike
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    divide the ring gear number by the pinion number
  4. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I looked at jegs and most the gears for the D60 have 41 teeth. These are Richmond Gears
    3.73=41-11
    4.10=41-10
    4.56=41-9
    4.88=39-8
    5.13=41-8
    5.38=43-8
  5. Toledo
    Dec 10, 2001
    207
    Thanks. I should have known that I would need the pinion also.
