Of TH400's and torque converters
Discussion in 'The Garage' started by dremu, Nov 26, 2006.
  1. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Just yanked the '400 out of my CUCV. I note on top it says "HD". This make it anything special, like is there actually a TH400HD? Wouldn't happen to be a TH475, would it?
    Also, the torque converter has SIX bolts, and not three, like my TH350's and the other '400 I've pulled. Is that weird, or in line with the above?
    Finally, what FREEKIN IDIOT at GM put *some* metric hardware on this thing and some SAE? :doah: :mad:
    -- A
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Yes, TH400HD for 4x4 use.
    Thicker casting IIRC.
    No, not a TH475.
    Six bolts corredt for the TH400HD.
    All of the GM idiots.
    (seriously, global economy, low cost, outsource parts, etc,etc,etc.)
  3. dremu
    Feb 27, 2000
    15,970
    462
    Well, I could but hope for the '475 :)
    And as for the metric part ... just, grrr.
    Thanks!
    -- A
  4. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    the HD does mean it's a 475!!! throw a shift kit in it and check the accumulator piston for the front band. It is ceramic and can break leaving you without 1low, I got an aluminum replacement for mine from AA beep beep mco AMCO
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Doesnt mean its a 475. My 400 is stamped HD, just has a thicker housing and a bolt on flywheel inspection cover, instead of the sheetmetal one with a couple screws.
  6. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    X2.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Isnt the only differance between a 400 and 475 the way the gears are cut? ones helical and ones straight right?
  8. 85-m1028
    Apr 26, 2005
    485
    here's what I'm going by....
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    And htat says nothin as to the stamping on the case... The stamp (more appropriatley, a cast) means nothing more than thick case/ bolt on cover and i belive only in 4wd's.
    If what you are saying is true every 4x4 truck made with a 400 would really be a 475... this is NOT the case...
  10. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Argue with that!
  11. Slapperbar
    Nov 29, 2005
    2,747
    3
    Damn I'm slow.
  12. 85-m1028
    Apr 26, 2005
    485
    actualy I think a case stamped with K is just the standard 4wd, all 4wd cases came a bolt on inspection cover...
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    along with an hd:rolleyes:
    as far as ive ever seen there is no way to tell a 400 from 475 from CASE alone
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Besides that page shows nothin about an HD cast into the bell...unless its written in invisible ink:rolleyes:
  15. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    AFAIK, they made a standard case, a "K" case and a "HD" case. both the k and HD case have a bolt on inspection cover. i have seen both in 2wd and 4wd vehicles. not sure exactly what the difference is. i have a 79 motorhome with the th400 HD case.
    IIRC, the only difference between the th375 th400 and th475 is the rear output shaft and yoke size.
