Off camber engine idle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by newyorkin, Aug 13, 2001.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Hey all. Not a major question here, just wondering about something.
    I had my truck pointed upward this weekend on a dune-type hill. I'd guess it was maybe 45 degree angle, but have no idea what it could've been (my short upper hitch ball was on the same level ground as the rear wheels, truck has 4 inch lift, 33"'s). I parked it there to get out and take a picture, and noticed the nuetral idle seemed boosted by about 300 rpm, to make it tach at 1000. I rolled back down later and threw her in park, idle was back around 700. I didn't think about it much then, but now I'm wondering what the heck could've caused it. More fuel to the rear cylinders or something batty like that?? This was one of the first time's I've had it at a sharp angle and put it in park (usually don't stop until I'm level again), so this could be normal for all I know.
    Any thoughts from the pros?
    Edit: It's a 350 w/TBI
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**<P ID="edit"><FONT class="small">Edited by newyorkin on 08/13/01 11:55 AM.</FONT></P>
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Carb related? Are you injected or carb'd?
  3. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Oh, right. 350 TBI
    Ratch
  4. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    just want to top and get some more info.
    Ratch
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Maby some frame flex was pulling on your throttle cable some how?
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    That's what I'd lean towards. Some body/frame flex pulling on things a bit.
    I highly doubt the TBI has anything to do with it; the whole reason a lot of people swap to injection is to end off-camber/uphill/downhill engine problems.
    It's always darkest just before it goes pitch-black...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  7. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Frame flex makes sense, but The wheels were pretty even, kinda riding straight up a dune.
    I figured maybe this was something someone had seen before, and I'm curious, not worried. I didn't think TBI would have anything to do with it, just wanted to eliminate carb from the possibilities.
    Ratch
    &lt;a target="_blank" href=http://k5.8m.com&gt;k5.8m.com&lt;/a&gt;
    **Ever stop to think... Then forget to start again?**<P ID="edit"><FONT class="small">Edited by newyorkin on 08/14/01 10:15 AM.</FONT></P>
