Off camber oil fixes?
Discussion in 'The Garage' started by Thumper, May 27, 2005.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Hey guys,
    Has anyone else experienced a oil pressure failure as a result of being off camber or tipped almost over?
    Anyone have any fixes they have done to prevent this situation?
    I seem to have spun a couple bearings when I got stuck very off camber. The truck idled for nearly 10 mins tipped over at near 40-45*, now I have a small bottom end knock, and 0 psi oil pressure. (ya ya... dumba$$ never thought to shut it down :) )
    I have been searching for dry sump systems... big $$ but it shouldnt be too hard to custom build some sort of system like that?
    What about those oil pickups that rotate around inside the pan whichever direction they need to be at the lowest point?
    Thanks for any input!
    Mike
  2. Thumper
    1,582
    Alberta Canada
    Well, update... I started it for a minute today just to settle my mind that its screwed... and lo and behold I had about 40psi oil pressure and NO knock when she started. As it warmed up, the pressure dropped to around 10-15psi, slight top end noise, but no knock. I am going to go ahead and pull the pan off and prolly swap the main bearings out to restore my pressure, but it kinda sounds like I was all worried for nothing.
    Has no one done any type of upgrades to the pan or pickup to keep oil flowing when youre tipped over?
    Mike
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    A lot less expensive would be an oil accumalator.
  4. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I run a quart more oil than I'm supposed to ,and I use Duralube. but I'm carbed so it stalls loooong before theres danger of engine damage.... whats an oil accumilator?
  5. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    4trolls, whats an oil accumilator?
    I think when the motor loses its oil pressure its gives the motor a shot of stored oil. Not to sure though.
    mike
  6. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    an oil accumulator is what I call my driveway :D
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
