Off My Rocker
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rob 85K5, Mar 24, 2000.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    I have been having a problem with the rocker arm on one of the exhaust valves loosening enough to not work at all. It has happened twice now. I put a new rocker arm, ball, and nut on last night and it is still happening. I have checked the pushrod and it isn' bent. A friend said maybe the valve spring is weak and that is causing the problem. Anyone else have an idea? These are aluminum heads with self centering rocker arms.
    I am using the factory style nut, not the poly locks with the set screws. If the valve spring is the problem, I don't see how that would help.
    Does anyone make a tall centerbolt valve cover?
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  2. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Are you using the locking nut with the set screw at the top or the factory type nut?
    CB
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Just a thought...are the stud threads OK? That is, the threads that the rocker arm nut uses.
    ken
  4. OLDSTEEL
    OLDSTEEL 1/2 ton status
    Mar 11, 2000
    107
    SANDIEGO CA
    You should look at the studd it could be the problem. I would all so put the self-locking nuts on. You may find the tall valve covers in P.A.W. or Summit.
    74 K5
    Leave it like you found it, or better!
  5. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    I had a similar problem .It turned out to be a flat lobe on the camshaft.Just a thought.
