Off-road anti swaybars?
Discussion in 'The Garage' started by wfo163, Jun 26, 2003.
  1. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    Okay I need this idea explaned to me. No sooner do I get a sway bar disconnect when I see these off-road swaybars by Anti-Rock. I guess I am just a little confused as to why when we spend thousands making a suspension super flexy do people then go and put a heavy duty system in that takes away that flex? Can someone give some insight into this? Even the Karnivore that BFG is giving away has one. Thanks guys!
  2. wfo163
    Jan 11, 2003
    100
    Charlotte, NC
  3. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    The Currie anti-rock is for a TJ, both it and the Karnivore use coil springs. Too much movement is bad when you are off-camber.
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    the anti-rock swaybars are not as effective at controlling body roll as the stock swaybar (on a TJ) but still do somewhat control it. The anti-rock bar has much longer arms coming off of it which equals more leverage over the swaybar which equals less resistance to rolling..... but it sure handles better than having no swaybar at all! I am looking into making something similar for the rear of my K5 using a torsion bar from an A bodied mopar (just the right length to span from one side of my frame to the other) All the wheel travel in the world is worthless if you can't control it.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    So you've got this mondo-bitchen super-flex suspension and you're out wheelin when one of the fronts drops into a hole. The body will immediately flop over to the low side and try to go on over since you have nothing to really control body roll.
    Put on a anti-sway bar with a really low spring rate, low enough that articulation isn't hindered - only delayed, and now the body is controlled. It can still flop over, but it now takes longer to do so. Long enough for you to goose it and pull that front back up to more level ground b4 your ride flops on it's side.
