Off Road Design 1" body lift
Discussion in 'OffRoad Design' started by jrsheets, Mar 15, 2004.
  1. jrsheets
    jrsheets Registered Member
    Mar 15, 2004
    68
    Katy, Texas
    Off Road Design 1\" body lift
    Hey everyone, im new to this forum just like to say hello. Anyway, Im in the process of replacing the rear cab floor panels from the rear seat to the tailgait on my 85 K5. The body mounts have come up through the body and rusted out. Along with the tail pan basically gone. So im in the market for some new body mounting. Does the 1 inch kit come with everything i will need to totally replace with whole body mount setup, or will i need to buy some parts. Im not sure what is still good on the stock mounts yet. Is there ways to "wing it" without using the expensive mounts ive seen in catalogs. Some funny washers that cost $10 a piece? Thanks everyone, let me know if you've had to do similar work to your rig.
  2. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    Re: Off Road Design 1\" body lift
    You will need to buy new body mounts (which ORD sells). The body lift doesn't include or replace them.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Luckily the rear doesn't use any goofy stock "washers", it's pretty simple stuff. You will need a mount kit and the body lift, they're separate kits but once the floor is back in, get the kits and you'll be set. Between the 2, you have everything you need.
