Off Road Design???
Discussion in 'The Garage' started by Mr.Chevy4x4, Jul 19, 2006.
  1. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    What happened to their site? Are they still in business? What gives?
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
  3. goldwing2000
    goldwing2000 Guest
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    That URL takes me to Network Solutions, "This domain name expired on 07/13/2006 and is pending renewal or deletion". Maybe somebody forgot to renew the domain name registration.
  5. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    I'm getting the network solutions site also. Not good! I needed some info on their doubler setup.
  6. 70jimmy
    Mar 3, 2000
    5,962
    252
    I just clicked on the links in both my post and goldwings and took me right to it???
  7. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Maybe you guys still have the site cached on your local machine.
  8. 70jimmy
    Mar 3, 2000
    5,962
    252
    [FONT=Arial, Helvetica, sans-serif]Doubler™ Quick Facts and FAQ answers[/FONT]
    [FONT=Arial, Helvetica, sans-serif]Gear reduction of NP203 gearbox: 2.01:1
    Gear reduction of NP205: 1.96:1
    Gear Ratio of combined transfer cases: 3.94 (basically 4:1)
    Overall Length of assembled 203 with NP205: 21.5" from front of 203 to ujoint center
    Overall weight of Doubler™ assembled with 203 and 205: approximately 240#
    Weight of Doubler™ kit: 24#
    The lowest point on the NP203 is about 8.5" below the drivetrain centerline. The NP205 is easily rotated to match.
    [/FONT]
    [FONT=Arial, Helvetica, sans-serif]The NP203 transfer case was used in GM, Ford and Dodge trucks behind these transmissions:
    TH350, TH400, SM465
    NP435, TF727
    C6, NP435
    The NP203 gearbox is adaptable to many other transmissions but can use a factory adapter with the above mentioned transmissions.
    [/FONT]
    [FONT=Arial, Helvetica, sans-serif]If you have a Ford front axle (or other application with the differential on the driver side) you need to use a Ford NP205. If you have a GM front axle (or other application with the differential on the passenger side), you need to use a GM NP205. The 203 and 205 do not need to be the same brand, we can mix and match to suit the parts you want to use.[/FONT]
    [FONT=Arial, Helvetica, sans-serif]The GM Doubler™ kit requires a 32 spline input NP205 which came in GM trucks with a TH400 transmission from '76 to '84. We have a conversion kit to turn other versions of the NP205 into a 32 spline input.[/FONT]
    [FONT=Arial, Helvetica, sans-serif]Ford applications will use any married ford NP205. All Ford married 205's came with a 31 spline female input gear. No modifications to this case are required.[/FONT]
    [FONT=Arial, Helvetica, sans-serif]We recommend dual crossmembers for mounting the Doubler system. You can use lightly modified factory crossmembers for many applications or click here for some ideas on custom high clearance mounting.[/FONT]
    [FONT=Arial, Helvetica, sans-serif][/FONT]
    [FONT=Arial, Helvetica, sans-serif]Maybe this will help????
    [/FONT]
  9. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Works for me:D
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    nope its not cached, I went to a page I've never visited before "Employment" and it worked
    [FONT=Arial, Helvetica, sans-serif]EMPLOYMENT OPPORTUNITIES AT ORD"[/FONT]
  11. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I'm getting the Network Solutions page also.
  12. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    When you renew a domain, it may take up to 24 hours to "refresh" the dns...
  13. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    its not working for me too.
  14. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    You could be getting redirected by a trojan or malware. If you go to www.majorgeeks.com, click on spyware, then download and run AdAware, may take care of the problem.
  15. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Could be, but I doubt that all of us are getting it.
  16. Emmettology 101
    May 9, 2000
    8,126
    FL
    I clicked on an above link and it worked for me.. Hmm...
  17. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    werks fur mi....
  18. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    It is working now....thanks everyone!
  19. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Our registration emails and paperwork were sent to old addresses and we got them the end of last week so we have a day without the website before everyone gets it up and running. Kind of a pain but not the end of the world. As always, if you're needing any help and don't get it by email or online, pick up the phone and CALL. We certainly don't mind talking to people.
    SW
  20. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Please refer to the post immediately above this one.
