Off Road Light Mounting
Discussion in 'The Garage' started by littlejimmythatcould, Feb 3, 2007.
  1. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Where do you mount your off road lighting? On the hood was the only spot I could think of with the top off in the summer time. Any ideas? Post up some pics of your unique mounting positions.
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    I'll be mounting a set of KC Slimlites on the front frame horns under my bumper. I think it'll look pretty good on my K5...
  3. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    See you took my advise lol
    Well I say get a kool bumper and mount the lights to that if not mabe cut out holes in you grill and install them as if they were highbeams but only use them for offroad use
  4. littlejimmythatcould
    Feb 6, 2006
    797
    Clovis, NM
    Yeah, I had thought about Hartley truck's grill replacement. But part of me likes them on the hood because they are usefull for uhhh... hunting. I wish I had a roll cage to mount them on. I wonder if the brush guard on the front would be in the way of the lights if they were in the grill. I've seen someone's lights that were mounted on what looked like the side of the windshield with some kind of bracket. That I think would really work for me but I need a picture of one to make one.
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Do u have a pic of the front of your truck if u do post it up and ill see wat i can do with photoshop to help you deside and i mean a pic like my avatar
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I made a quick detatch bracket that bolts to my bumper using captive nuts.
  7. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey Do you have part numbers? I want to do the same.
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Errr....no! I made an alloy bracket and used 4 x 12mm Wurth compression nuts in the bumper. All home made. The lights are Warn 6" units. I made a weather pack connector for the electics.
  9. burban89
    burban89 1/2 ton status
    Oct 16, 2006
    1,861
    Port Clinton, Ohio
    Could you take some up close/detailed pics. I would like to see how you did that. I like the idea.:waytogo:
  10. littlejimmythatcould
    Feb 6, 2006
    797
    Clovis, NM
    I'll go out and snap one tommorrow. I can't believe I don't have any straight on pics of my truck out of all of the ones my wife and I have taken. I tell you what though, that photo shop thing is neat. Wish I knew how to do it. I don't like computers, if it wasn't for CK5 or other neat websites :rolleyes: I wouldn't go near the things.
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Kool I'll be here waiting for the pics and compters arent that bad once you get use to it.
  12. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
    I made a custom grill out of expanded steel, and mounted my Hella 500s behind the expanded steel...helps protect them from rocks, branchs, and theives too! just a thought...and only cost me about 25.00 to build the grill and the light mounts too! (I used 4" shelf brackets for the lights)
  13. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    made a bumper, mounted lights behind the 'stinger' so the never get hit. pic is of my old suburban getting rid of the bumber too.
    IF you want unique get some flat stock steel 1/8th or 3/16th cold rolled ( it is a little harder) and make a brackit that will bolt in to the top fender wher it bolts in between the hood and cowl.
    bend it up so the brackit will stick out there then bend it level anf mount the light on it. Wireing can go right throught the same gap. That way you can just reach out and move it for hunting, or to twist it ahead to see around the turn when off roading at night.
    pic of my truck.
  14. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    What headlight setup is that?
  15. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    OK, give me a day or two and I'll post up.
  16. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    Custom:pimp1:
    3 lights per side 5 bulbs, plus the yellow and clear spots
    14 bulbs total, about 1130 watts enuff to kick the truck in the balls idleing if you turn them all on at once. :D
  17. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    hey man, if I come by sometime, will you show me how you did that?? It confused the hell out of me before, but it quickly grew on me.
  18. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Ally angle and plates welded up and drilled for 12mm bolts, counterbored to recess the heads. This was all I could take before the camera battery died!:doah:
  19. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    hey bud good to see your a mamber! :waytogo:
    yeah i can show you for sure, let me know we can work something out :D
  20. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    EXCELLENT!!
    Yeah man, I ponied up the dough. Figured it was about time to do so!
