Official S10 Rebody Topic
Discussion in 'Center Of Gravity' started by sled_dog, Dec 20, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I mean besides white knight. Issue I have with the white knight is that when he first put the s10 body on it had like the equivalent of 6" body lift or so. I want to be right down on the frame for lower CG, or as low to the frame as I can get. My biggest issue will be the massive shifter for my 465 sticking up into the s10.-
  2. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Re: S10 Hybrids, anyone done an S10 Blazer?
    Yes.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    any close up pictures of yours? I've only seen your avatar pic.
  4. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    These are the only pics I have to show you.
  5. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    Steve's Blazer?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    keep looking man its pictures from a trail ride.
  7. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    Yah, we had that 6" body lift cause it was done in a hurry fot TTC2001. We should have worked the firewall. Also steering was an issue. The newest version of the knight has no body lift. It is 1 foot 6 inches lower in total compared to the full s-10 blazer version. We went full hydraulic steering which solved one of the majot problems.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I think next winter I will be going full hydro and coilovers all around but thats a year off.
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Here is a few more of James's S10 Blazer conversion:
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    who does the red and white S Blazer belong to? i'd like some more info on it, that's one sweet rig!
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    jac6695
  12. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Do any of you who have done this swap, have pics of the new body mounts you built on your frame? Could you take pics for us?
    Thanks. /forums/images/graemlins/thumb.gif
  13. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I totally want to do this, only with a 4dr S-10 Blazer. I think the wheelbase is nearly the same as ours. With a top cut off, and a full cage I think it would look very cool!
    Mike
  14. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    Neil, you don't want to see pics of mine (looks kinda sloppy /forums/images/graemlins/1zhelp.gif). On the front cab mount, I used 2" box to adapt the S body mount to the fullsize frame. With the next two, I cut the frame mounts and moved them to meet the body.
    My brother (who did an ext. cab like you are) made frame mounts with thin wall box (like 4"x4" or so) cut it down to look like a factory frame mount (wedge shape), drilled the hole for the rubber mount, and welded it to his frame. Turned out real nice. I might be able to get some pics for you. I will try. Nice thing with the ext. cab, you only need to make two mounts each side.
  15. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    I wish I did the 4 door body. I would do it from a Sub frame for extra wheelbase and still lengthen the front clip for more room. /forums/images/graemlins/thumb.gif
  16. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    is this S-10 on a full size frame or stock S-10 frame?
  17. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    77 fullsize. I found the 70's frame works on the S- Blazer body better than 80's.
  18. big k5
    big k5 Registered Member
    Nov 19, 2003
    88
    Sautee Nacoochee,Georgia
    I have a 77 k5 that i'm setting up for pure off road use & i also have a 91 4dr s10 with a blown engine. the thought is VERY tempting to slap the s10 body on the full size frame,remove the doors,ect. & running a 400ci/sm465/205.......HMMMM ??????????? maybe it will happen
  19. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    How much frame would stick out in the front of the 4-door S-10 body on a K-5 frame? I'd like to know if I could mount a winch between the frame rails or on top heep style to keep my approach angle. Also, how much wider are the axles when the truck is on stock skinny tires? Is it possible to fabricate flares big enough to cover them for inspection purposes?
  20. big k5
    Nov 19, 2003
    88
    I'm not sure about how much frame would stick out in the front,but from the hybrid trucks i've seen in tellico there is enough space to put a winch up front.thats were most are running them.also i don't know if the ones i've seen were k5 frames or truck frames??? as far as the width of the axels I'm not sure I really haven't reasearched any of it yet. All I know is I have the parts lying around & the desire to do it.If I do it I'll take pics as I go and post them all on the site (once i figure out how to do that)You asked about flares to pass inspection,I've seen some of the tenneessee trucks use old(rubber) bed mat material as flares it seems to work pretty good.I'm lucky I geuss because we don't have inspection here.
