Offoad designs 14 bolt disc brake brackets
Discussion in 'The Garage' started by BlitzK5, Aug 13, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I bought Offroad designs 14 bolt Disc brake brackets. I was originaly going to use my 1979 3/4 to rotors and calipers, however to get them turned is almost the same price as new ones, And also i still need to get longer wheel studs for this setup which will cost me around $80. I'am now thinking since I should get new rotors is there any 3/4 ton rotors that have a thinner mounting surface like the original drums for I can reuse the origianl wheel studs to save me some money. Also is there any calipers out there with the parking brake on it that will fit these rotors and brackets from offroad design for I can be street legal. I also have the 10mm banjo bolt SS brake lines from them aswell so I will need a set of calipers that will work with them to. Anybody out there with these brackets? and if so What kind of setup did you use?
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Calipers - 76-78 Caddy Eldorado Calipers.
    Pretty pricey, and new ones DONT come with the emergency brake levar. You will have to find some junkyard ones and use the levar, or fab up a wrench like 85mudblazin did.
    Also for the caddys you will need a 7/16 bajo bolt, and for brake lines i used some off of a 79 chevette.
    I havent heard of any wheel stud issues, but then again, i havent completed my project yet.
    Good luck
    -jon
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I re-used my factory studs without any issues. I bought new rotors for a '79 K20 and they worked fine.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    what he said.
  5. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    are you using alum wheels? is this the need for longer wheel studs??
    caddy calipers are prob the only way to go for a cable e-brake
    i'm trying to find caddy levers from delco but it doesn't look too good... but DIY4x drills their brackets with 4 extra holes to allow you to rotate the bracket up more to keep the e-brake cables further out of the way of brush/rocks...
  6. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    just reuse the studs that are theyre if the threads are ok
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    You do lose a little thread due to the rotor being thicker than the drum was where the wheel studs go through. If your using open ended lug nuts as long as you have 100% thread engagement it doesn't matter.
  8. BlitzK5
    Jul 29, 2005
    288
    I have a set of Eagle 58 wheels so I think thats why my stock studs are not working. There to thick.
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If your 14 bolt had the 11" drums you will need to buy new studs for the 13" drums and you are set. :thumb:
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i got new wheel studs for $1.50 each at Advance Auto, and they are a little longer than the original ones, i had 11" brakes.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We just did my 'burb with a K30 rear and had to go with dually studs, the 1-ton studs didn't work with my welds. We have the studs in stock now but they're not anywhere near 1.50 each, more like 2.50 each, probably because we're not a discount parts store and the studs are quite a bit longer.
