Offraod S-10
Discussion in '1983-2005 S-Series models' started by 1979jimmy350, Jun 2, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am taking a 1989 S-10 Blazer and turning it in to a offroad truck. I am going to put a GM inline six in it with the stock drivetrain. What will I need to do to use the four wheel drive. It has a NP231 transfer case in it
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Offroad S-10
    How much of the firewall and dash are you planning to cut out to make the inline 6 fit? /forums/images/graemlins/yikes.gif That's a pretty long engine!
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    Re: Offroad S-10
    the entire body is coming off because it is so rusted so space is no issue
  4. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    well you are going to have to either have to extend the engine out the front where the radiator is , or you will have to lengthen the front shaft and shorten the rear shaft.
    i think the old inline six has the same bolt patten as the
    4.3 bellhousing but i could be wrong. if so , you will have to see if there is an adapter to hook the 231 up to the
    original tranny. if you pull the tranny from a k5 blazer
    with an inline 6 , you could see if a 231 can be clocked
    to have a driverside drop. good luck.
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I am just going to use the tranny that came out of the S-10 the 700-r4 has the smae bolt pattern as the inline six i am wondering about the front axle how is 4x4 function controalled?
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    A vacuum switch on top of the transfer case engages the central axle disconnect when the case is shifted into 4WD. /forums/images/graemlins/cool.gif You can also buy a manual control unit, called a Posi-lock, for around $100.
