Offroad Design 4" shackle flip rear. - ?Front?
Discussion in 'OffRoad Design' started by johnnyK5, Dec 26, 2001.
  1. johnnyK5
    johnnyK5 Registered Member
    Oct 5, 2001
    95
    Washington, PA
    Offroad Design 4\" shackle flip rear. - ?Front?
    I have a 79' Blazer Stock w/33" BFG's. I plan on 35's , a little fender trimming and I'm pretty sure on getting ORD 4" shackle flip for the back. My question is what to put on the front to level things out. - 4" Skyjacker springs? Thanks.
    "Baby it first, floor it second!" -correct.
    "Floor it first, baby it second!" -incorrect.
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    Re: Offroad Design 4\" shackle flip rear. - ?Front?
    yes get 4" lift springs for the front
    68 SWB 4x4 1 of 1,449 made 327, 465, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
  3. johnnyK5
    Oct 5, 2001
    95
    Washington, PA
    Ok, thanks. -now im thinking bout 38x12.5x15's on my 15x8's.
    I may have to go with a 6" spring setup and 1" body &amp; fender trimming[​IMG].
    " IT AINT DEEP !! " -common phrase from that guy who doesn't drive to the local mudhole.
  4. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    All depends on how much fender trimming you wanna do. Running 38s with just 4" of suspension lift (no body) is definitely possible, you'd just need to do major fender trimming. I never plan on having more than 5" of suspension lift on my current rig in addition to the 1" of body lift. If I need to fit bigger tires, thats what the sawzall is for. =)
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    These guys pretty much have it lined out for the lift.
    I'd recommend the TCI springs, either that or a custom spring would be the best way to go.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
