Offroad Light install problems
Discussion in 'The Garage' started by hytech_rednek, Dec 26, 2006.
  1. hytech_rednek
    hytech_rednek Registered Member
    Oct 2, 2006
    6
    Redding, CA
    Ok, I am installing off-road lighting with a relay and a SPDT (single pole double throw) toggle switch.
    Relay attached as follows:
    #87 to lighting
    #85 to ground
    #86 to toggle +
    #80 to fused battery connection
    Toggle connected as follows:
    12v+ to #86 relay
    ground to ground
    accessory not attached
    Obviously this is not working, please help me out on the CORRECT way to install. Thanks for the help.
  2. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    When you say ground to ground, does that mean you wired the ground on the switch to the ground on the relay?
    You should attach those to a grounding poing on the frame or body.
    Are the lights grounded?
    Do they work if you touch the + wire directly to the battery?
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I bolded what is incorrect.
    The 12V + must be a positive 12volt source.
    The ground is ground (obvious)
    The ACC is what goes to the relay terminal 86.
    You have to power that terminal on the relay or nothing happens as you found out. You can pull this power from you fusebox under the dash, since it is a small amp draw (.7 amps)
  4. hytech_rednek
    Oct 2, 2006
    6
    Redding, CA
    yes, I do know what a ground is and all ground points are to the frame and checked with tester. Thank you for the clarification on the relay-toggle connections...I am going to do that right now.
    P.S. - The pic is much help thanx
  5. hytech_rednek
    Oct 2, 2006
    6
    Redding, CA
    WORKS GREAT!!! Thanks for the assistance.
  6. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Glad it worked out for you!
