Offroad lights
Discussion in 'The Garage' started by cegusman, Oct 6, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What are some good non over priced offroad lights everyone is running?
    Whats the difference between the Fog light, Driving light, Spot light, and Flood Light?
  2. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I had a set of the K.C. Daylighters that I payed about $100 for a couple years back. Dont get the chrome ones, they rust. I think they offer stainless. They were 6 inch round. Really lit up the night. I think they offer 100 watt and 150 watt lights. I dont hav a ton of $$ to throw at my truck so for the next pair I may just get 100 watt Summit round off-road lights. I think they are $60-$70 for 2 and wiring. The fog lights usually just provide a wide low beam that doesnt project very far. Wont do much good on the trail unless you just want to know whats 10 feet in front of ya. Driving are more like your headlights, just project a little brighter and farther. Spot lights are a narrower beam that projects farther, and flood are a wider beam.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a set of 100 watt halogen KC Daylighters on the front of my '90 Sub. They turn night into day... The serious Daylighters are the 150 watt sealed beam units that use the same lamp design as aircraft landing lights. I have a couple of those that will be going on the K5. They'll burn your retinas. ;)
    For on-road use I have a set of Hella 500 55 watt halogen driving lights on the '94 Sub, that are wired to come on with the high beams. They are MUCH brighter than the factory headlights, and have a nice, defined pattern. On the '90 I have a set of Hella FF50 55 watt halogen driving lights, also wired to come on with the high beams. They're very small and use free form reflector technology to define the pattern. They also throw a very bright, defined pattern.
    What you're mostly paying for in the more expensive lights are a better reflector and lens design. I have a cheap set of 55 watt "driving lights" that don't even throw as much light as my headlights. Meanwhile, the 55 watt Hella lights are just amazing. Hella spends more money manufacturing a quality product than the "El Cheapo" companies do. The results are quite noticeable...
  4. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    My uncle has a set of Lightforce offroad lights mounted on the bumper of his daily driver. He really likes them. He says they're great for lighting up dark backcountry roads. You can also change the beam patten and light color just by changing the lens cover.
    Flood lights are good for mounting on the rear so you can see what you're backing into :wink1:
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I've got both a set of 6" KC long ranges (read: pencil beam) and a set of the 8" driving pro comps. The Pro-Comps are good all around and compliment my factory lights nicely. I have the KC's aimed so their beams cross and shine into the ditches down the road....extremely handy for not leveling deer when blasting along at night. I'm probably gonna run a set of cheap tractor lights on my orange one since there's a good chance of damage no matter how well the lights are made.
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I had 4 KC Daylighters on my old '79. They're not called daylighters for a gimick either :eek1:
    The ones I had were either 150W/365,000candle pwer or 165/350,000 candle power ( cant remember but it was a combo like that). 4 of them would light up the road for a mile.
    I've still got them and am going to be putting them on my '81 when I get time.... like that'll happen :haha:
    $120/pair from summit is what I paid...but that was 4 years ago.
  8. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Some good info here, I'm planning on some on the '72 soon.
    I am going to keep my old-ass amber lights though. It is so nice when you're going up a relatively mild forest trail to turn everything off but those low amber lights and not scare every elk in four states or wake up every camper in the forest.
    Does anyone know if they make some newer, nicer amber driving lights too, might be good to replace those while I'm at it.
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    KC makes a good number of their rectangular lights with amber lenses. Otherwise cheapy e-bay models come with them a lot.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    They're 150 watt sealed beams, with 365,000 candlepower each. :eek1: They're the same ones I'm planning to put on my '75. :cool1: They're like miniature, portable suns. :wink1:
  11. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    OK, I knew it was something like that. And the "suns" comment is no understatement either.
    I've got 4 (the ones I took off my '79 when I sold it) are still down in my basement. I'm going to put 2 on the '81 and 2 on the tow rig.
    Mike
  12. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I run the $16 cheapies from walmart on my 4X and towrig. Works good and if one breaks or whatever your not out much.
  13. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    i got 8 6 inchers off ebay for around 140. i got 5 on the roof and 3 on the bumper, and they light up everything. i also took my alternator to an alternator shop where the respun it to crank 160 amps.
  14. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    IPF makes some good amber driving lights...
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Look around at http://www.kchilites.com/ Just ignore the prices. Those are suggested retail, you can do better just about anywhere. :wink1:
  16. spongeidys
    spongeidys 1/2 ton status
    Jul 6, 2005
    2,566
    Dillion, CO and Palmerton, PA
    good to know what those 150w sealed beam daylighers are gonna be like i scored a brand new pair off of ebay for 100 bux
  17. Mammoth2
    Mammoth2 Registered Member
    Aug 4, 2002
    42
    TX
    Ask Around What An H4 Bulb Is, An H4 Offroad Light System.
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Compared to what is available now, Daylighters are not the hot ticket any more. Their beam is too narrow to be very good for low speed use and they don't put out enough light for high speed use.
    Until you've ridden in, or driven a truck with serious off road lighting they seem fine. After that, well, I took mine off.
    The larger the lens & reflector diameter the better. For a cheap light I'd look at the Pro Comps or something like that. Maybe find an old set of Cepek's off a Monster wanna-be on ebaid. Then up rate the bulb to at least a 100 watts. Most of those lights use the H3 type of bulb, which is what the non sealed beam Daylighters use. PIAA and others sell high wattage H3 bulbs.
    Otherwise have a look at the above mentioned LightForce's and the Hella 4000's (HID or not).
  19. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I agree, there are better lights out there, but one advantage of the KC's is their price. Hella's with any sort of technology in them are major $$$ as are PIAA's and Lightforces. For serious speed (highway cruising, desert running) I think there are much better options, but for the average trail wheeler I think they're a nice compromise between quality and cost.
  20. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Well personally I dont plan to run Baja anytime soon in the K20. With the lifted leaf springs I cant get that much speed off road without bouncing all over the place and jarring every bolt loose. For late nut drives down a trail for the $$$ I think the KC's, Pro Comp style light are the way to go. If I had boo-koo bucks and/or building a high speed rig then I would look into some $300 pair of off-road lights.
    And a big :waytogo: daleearnhardt01 for the Robby Gordon helmet throwing Avatar!!! :saweet:
