OFFROAD PICS!!!! Me, K5_73 and WakeBoard&4x4er
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, May 27, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumIndex?u=1657641&a=13054440&f=0>http://albums.photopoint.com/j/AlbumIndex?u=1657641&a=13054440&f=0</A>
    WakeBoarders truck is the white one. Its a '91 with 4 inch lift and 33's.
    K5_73's truck is pretty stock with some 32's and no lift.
    And this list explains why my truck is so special. [​IMG] This is the first time I've put pictures of my truck on this website so I'll also include my massive list of upgrades. The sad thing is, this isn't even close to the complete list. On this list I tried to leave off boring things like heater core replacement for example and smaller things. ** means that I have the stuff, but its just not installed on the truck yet.
    1973 Chevy K-5 Blazer
    Engine:
    --New fan clutch.
    --New water pump.
    --Edelbrock 600 cfm, vacuum secondary 4 BBL carb, electric choke.
    --3x14 inch, K&N air filter.
    --Edelbrock Performer intake manifold, Vortec style.
    --Powermaster, 140 amp alternator.
    --Cloyes, double roller timing chain.
    --Edelbrock chrome air cleaner housing.
    --Rebuilt, 4 bolt main, 350 block.
    --New, L31, Vortec cylinder heads.
    --Chrome, centerbolt valve covers.
    --Comp Cams pushrods.
    --Comp Cams Extreme Energy camshaft.
    --New harmonic balancer.
    --All new hoses.
    --Gates alternator belt.
    --Rebuilt HEI distributor.
    --Accel: ignition module, distributor cap and rotor.**
    --Autolite platinum spark plugs.**
    --Mr. Gasket plug wire loom kit.**
    --MSD: 6A ignition box, coil, plug wires.**
    --TD Performance 1 inch swirl torque carb spacer.
    Front Axle:
    --Dana 44.
    --All new bearing and seals.
    --New set of Dana brand ring and pinion gears. 4.09 ratio.
    --New Dana large sized differential carrier.
    --Warn premium hubs.
    --4 inch longer brake hoses.
    --New drag link.
    --Dynatrac diff cover.
    --FourXDoctor diff guard.
    Rear Axle:
    --Corporate 12-bolt.
    --All new bearings and seals.
    --Moser axle shafts. Alloy, 30 spline.
    --U.S. Gear ring and pinion gears. 4.11 ratio.
    --Eaton(NOT Gov-Lock) limited-slip differential. Modified with 800 pound spring.
    --T/A Performance differential cover. 356-T6 Alloy.
    --ARP stud kit for main bearing caps.
    Tranny:
    --Muncie SM465.
    --Stock.
    --New clutch.
    Transfer Case:
    --NP205.
    --Stock.
    --Replaced front output shaft seal.
    Lift Kit:
    --Superlift 2.5 inch kit. New springs in front.
    --ProComp ES 3000 shocks.
    --ProComp ES2000 steering stabilizer, new hardware and install kit.
    --Skyjacker 2 inch dropped pitman arm.
    --Skyjacker front U-bolts.
    --ORD greasable main eye kit for front springs.
    --ORD greasable heavy duty shackles, front. 1/2 inch longer than stock.
    --ORD swaybar bushing kit.
    --ORD 4 inch shackle flip kit for rear.
    --ORD greasable rear spring bushing kit.
    --ORD swaybar correction/disconnect system.
    Other:
    --15x10 inch 589 American Eagle wheels.
    --33x12.50 Super Swamper radials.
    --New 2.25 inch exhaust pipes from manifolds to mufflers.
    --Warn Classic winch bumper.
    --Optima red-top battery.
    --Rebuilt master cylinder and power brake booster.
    --New front and rear driveshafts, custom made by Power Drive.
    --2 2-chamber, 2.25 inch Flowmaster mufflers and new tailpipes.
    --ORD steering box frame gusset.
    --4 point rollcage.
    --Dual shock mounts installed on front.
    --VDO tachometer.
    --Autogage mechanical oil pressure gauge, relocated in dash.**
    --Autogage coolant temperature gauge, relocated in dash.**
    --Autogage voltmeter, relocated in dash.**
    --Factory skidplate for gastank.
    --Factory skidplate for tranny/transfer case with new Grade 8 hardware.
    --Aftermarket rear step bumper.
    --Grant steering wheel.
    --New radiator.
    --Dual air horns.
    --Gold plated, Rockford Fosgate battery terminals.
    --2 gauge and 1/0 gauge welding cables for battery cables.
    --New tie rod.
    --New drag link.
    --2 new yokes for rear driveshaft. Transfer case/axle.
    --2 new GM bumper braces for front bumper & hardware.
    --1500 pound capacity ratcheting tie down strap for battery.
    --New GM battery tray and tray brace.
    --2 Pro Comp 130 watt, 8 inch lights.
    --Halogen driving lights for rear bumper.**
    --700 watt Dick Cepek dual relay for lights.
    --2 cloth bucket seats from later model K5.**
    --Tuffy locking console.**
    --40,000 pound Keeper tow strap.
    --Fire extinguisher.**
    --Rubber front floor mat.**
    --Painless Wiring, 7-circuit Cirkit Boss auxilary fuse block.**
    --DEI 5000 alarm with 1 extra siren, 2 piezo sirens, radar sensor, batt. back-up.**
    --Hood brace kit.**
    --60 inch, cast steel Hi-Lift jack and bumper lift attachment.
    --30,000 pound clevis hook for rear.
    --Extended breather hose for front axle with Fram fuel filter.
    --Front tow hooks.**
    --B&M shifter handle.**
    '73 K5
    Chevy good...Ford bad
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    very nice[​IMG]
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  3. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Are you sure that isnt everything ? lol !
    ~ <font color=red>S</font color=red><font color=blue>l</font color=blue><font color=orange>y</font color=orange><font color=yellow>D</font color=yellow><font color=purple>o</font color=purple><font color=green>g</font color=green>
  4. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
  5. '73 K5
    1,763
    Kansas
    I know, I know. lol Its pretty bad. I had 2 other Blazers before this one and I still hate myself for selling each one. And I lost money when I sold them. So I figured I'd just buy my favorite year with a 4 speed and build it up, leave no bolt unturned and never sell it. That way I don't lose money and I won't regret selling it.
    '73 K5
  6. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    So where were you wheeling? It looks like a bit of rain and you might have got to use your recovery gear some! [​IMG]
    Nice trucks, I love the full convertables!
    Rene
    <font color=red>If at first you don't succeed...skydiving ain't for you!</font color=red>
  7. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    I see how it's going to be. You don't post the pics of my truck doing what it does and you don't bother to call me when you go out mudding. What's wrong with you? Geez, why does everyone have to be so insensitive? That's fine, NO HARD FEELINGS! I want to know why you didn't give me a call.....am I just to weird for you, or is it because Matt's annoying?
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Did you do any wheelin' or just take pictures ? Just kidding, I love to see them .....keep em coming.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  9. '73 K5
    1,763
    Kansas
    Rene: It was in northeast Wichita...just kind of an undeveloped area. People go out there to fish and stuff. Yea some of those ruts were really deep and wouldn't have been too easy to cross if they were muddy. I did get to use the tow strap though. The black Blazer got high centered on his running boards. haha
    '73 K5
  10. '73 K5
    1,763
    Kansas
    Alex: Man, I think you did more bitching in that last post than my girlfriend did all of last month. OK stop crying man, I'm just kidding. I haven't posted your pics yet because I'm lazy. I didn't call you about it because you didn't call me that one time you went to Augusta. OK just kidding again. It was a last minute deal. The guy with the white Blazer was in town from KC to get married and he just wanted to get some "action" pics of his truck. We didn't stay there too long since the black Blazer and mine had the interior ripped out, including shifter boots, meaning we didn't want to get in the mud. We just ran up and down a few hills and took some pics.
    '73 K5
  11. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    Oh yeah, you also forgot to mention that those DEEP ruts are mine. It was pretty weird seeing you today going down hillside. I see the car and I think, "That's got to be Klunky, but, I'm in the ghetto." Sure enough, there you were. hahaha So, are those ruts pretty deep out there? The reason why I'm saying they're mine, is because nobody goes out there much anymore. Who knows, maybe somebody made them bigger. We need to go again. See ya!
  12. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    You guys need some mountains in Kansas! J/K Sweet trucks though!
    Ron
