Offroad wheelbase
Discussion in 'The Garage' started by MrArmyAnt, May 2, 2006.
  1. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    What's better, a shorter wheelbase or longer one for offroad? Mud? I assume shorter is better for rocks?
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    that is a good debate. no correct answer. good aproach and departure angles are always good though. my K5 has a WB of 115.5"
  3. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Different types of offroading need different wheelbases. For climbing ledges a long wheelbase is best. (picture a crewcab trying to climb a 4ft tall ledge vs a samurai) Through the tight trees though you would want a short wheelbase for better manueverability. A good formula imho is wheelbase = 3x tire size. So a truck with 35" tires would need a wb of 105". This usually ends up netting you the best stability vs breakover angle etc.
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Well damn with 47's thats 141 and I'm at 152, thats almost correct... :D
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    lol see good formula eh. I will be stretching my wheelbase to 117.5 when I throw on my 42's. A little short but we have lots of tight trees around here.
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    how ironic, with a WB of 115.5 and 38.5 TSL's, i am dead on 3x.
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    40s and a 118" wheelbase I am close too. I haven't seen that idea before but it sounds good to me, I have wheeled both long and short(sami and a blazer) and truly its a tossup my sami could get in and out of anything and since it was so short and narrow some obstacles for others became non obstacles for me. My blazer can climb anything it seems, but sure is hard to get in and out of stuff. Long wheelbases are nice in the mud but my blazer feels pretty much the same as a buddys longbox extended cab Ford (like 137" wheelbase) So to sum it up, it seems that the best mix is between 100" to 120" depending on tire size. Of course if you are cool like willyswanter and can run huge tires like 47s you can go longer
  8. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    so does this mean that the sami is the long WB one?
  9. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    OOPs nope it was a swb sami ended up being about 85" in its last incarnation. Stock samis are 79.5 LWB samis are sweet
  10. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey that works...I have 35" and my wb is 104 :D
  11. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I just had to resurrect this....looks like you're gonna hafta go to fiddy-twos :D
    On a side note, I might as well ask you...I"m looking to build a party wagon like yours, but older and cheaper. I'll be running one tons with minimum lift and maximum hacking and 39" Michelins (maybe dualed out back :D ) I wheel almost entirely in a big open desert, not much rock. Prolly won't be able to get my wheelbase as short as yours with leaves... Whatcha think?
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I think a shortbox truck (117") is about perfect.
    I have 113" and it's too short.
    I had 131" and it was too long.
  13. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    I think you're right. Shortbed has minimum weight too. This truck pic below (brother's) lays the smack down.
    Wheelbase depends a LOT on terrain though...out here in the desert I used to wheel a big long Xcab Longbed Cummins Dodge on 35s without much trouble. Wheelbase was awesome for climbing, made J**ps look stupid all the time. My front tires would be at the top of the obstacle before the rears hit it and they'd be flipping over backwards
    :haha:
    And there's nothing as fun as blasting a big long heavy truck like that in donuts or up washes and around corners sideways! I once chased/passed some fool that kept blasting thru camp in his '79ish fullsize F*RD prerunner. Bet he felt foolish having my big fat stock diesel keep up with his "built" prerunner.
