Offset block question
Discussion in 'The Garage' started by Muddytazz, Jan 4, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Ok, I'm having a total brain fart today and can't think worth a crap for some reason. I've got some tapered offset shims from Az-kickin to fix pinion angle and to offset my rear axle BACK 1", but for the life of me I can't figure out which hole to use. I know the center one is for the pin to perch, but if moving the axle BACK 1" which hole do i use to bolt the offset block to the spring pack?
  2. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    Front hole. /forums/images/graemlins/thumb.gif
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    flip it over the use the back one?
  4. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    As you look at the picture the bolt should go thru the hole on the left and bolt to the spring pack. The middle bolt is for the spring perch. This will move the axle back and rotate the pinion angle up.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thanks Sean, thats kinda what i figured, but the brain wasn't working to well this morning /forums/images/graemlins/blush.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
