Oh boy! Another differental question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer_Boy, Dec 20, 2000.
  1. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    This one is quicky. '82 Silverado w/350, 700R4, and 31" tires. What the best all around ratio, its primarily a city truck with some off roading and lots of snow driving. 4.10, 3.73 or something different?
    "An old Blazer never dies, they just... rust away."
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    probably for you in the city, 4.10s or even numerically higher.....js
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, dude I am right now running the 350/700 with 3.42's and I have stock 29" tires. And she has plenty of power. SO with just 31's you should have great performance with 3.73's. Then you only use overdrive at 60+. that owuld be the best all- around. Im going to 3.73 or maybe 4.11 with 33's and a 700. But I dont do all the low end crawling that alot of these guys. Just be true to yourself about how your going to use your truck. But you sound like me, part time here, daily driver..... Thats just my thought.
    I miss my Ex, but my aim is getting better!
    <A target="_blank" HREF=http://mccordhouse.freeservers.com>http://mccordhouse.freeservers.com</A>
  4. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    3.73 are great for up to 31s but 33s need 4.11s
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I run 33's with 4:10's....if ya run mostly highway, with 31's, then 3:73's are ok.......on the highway, at speed, the difference between the two ratios is about 200rpm...I would opt for the 4:10...if you presently have a 3:42, or (numerically)lower.....you will have to change carriers.....good opportunity to upgrade....JD
  6. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I am running 33's with 3.08's. It drives fine on flat ground, but you slow way down on hills. I also tow with this set up. Don't get me wrong, it sucks! I will be changing axles soon though. I just wanted you know that 33's and 3.08's work, so 3.73's or 4.11's would be great.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
