Oh crap...busted shcok mount...am I S.O.L??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Dec 26, 2001.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Today while drive in typical Denver traffic, I busted my rear, driver side, UPPER shock mount...The previous owner had obviously tried to weld the mount the first time it broke but did a REALLY shoddy job and it busted again. Again the shock mounting bracket that is RIVETED to the left frame rail next to the fuel take busted right at the bend in the bracket... I went to BEAR frame and axle down in Littleton and they wanted $260 to fix it...No way in hell...So I went to the Chevy dealer thinking it would be easy enough to get a new rivet-on bracket...WRONG...it in not a service part!!! So where can I pick this bracket up? And when I replace it, can I replace the rivets with some decent bolts instead? If I cant buy a bracket, any tips on making one? I've never fabbed much of anything so I will need LOTS of pointers...Oh well, this is the first part I have officially broken on my relatively ne K5....RIGHT ON (I think [​IMG])
    Chris
    Was that a speed bump? No, just a Rice Rocket </font color=red> <a target="_blank" href=http://coloradok5.com/gallery/fortcollinsram>My 87 Blazer</a>
  2. dyeager535
    26,977
    IMO the reason they shear like that a lot of times is from the bolt or shock rubber bushing deteriorating, letting the shock "jackhammer" the bracket, upper shock stud, and the rivets on the frame. Obviously it was partially a design flaw, just one that takes a long time to find out. : )
    Use the "search" function, I'm pretty sure that piece IS available, and was discussed here. probably available aftermarket too. If I were making one, I would use thicker metal, maybe even reinforce the angle, and definitely, even with a stock piece, weld the shock stud to the bracket. (just don't use those crimped lock nuts or you'll ruinthe stud, now you can't replace it : ) I've had two of those bolt holes oblong on me, I guess I was just lucky it didn't bust the mount.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    UPGRADE TIME!!!...build a crossmember over the top of the axle between the frame and weld on tabs on the axle for the bottom shock mount then mount the top of the shock to the center of the crossmember you put above the axle...i am sure someone has some pics of this done...i have it done on my K5 but never took any pics
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Check another dealer, b/c i'm pretty sure you can get one, i know somebody mentioned getting a new one somewhere. But what i did was go to the bone yard, i pulled one off a Sub, i think it was even a two wheel drive, the bracket was the same, had all the same holes, only the blazer uses the two on one end and two in the middle, and the sub uses the two on the other end. it wasn't too bad drilling them out in the junk yard but drilling out the ones in my blazer were a pain, i had to pull the gas tank and get a right angle adapter for the drill, but it can be done for a lot less than $260
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Steve Frisbe has a <a target="_blank" href=http://www.mooffroadoutfitters.rockcrawler.com/whats_new.html>shock relocation kit</a> that is less than the $260 you were quoted, can give you more shock travel and is available as a bolt in kit.
    I think Jeremy (55Willy) is also in the process of making such a kit. if it is already busted, time to upgrade![​IMG]
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Will I be able to use Steve Frisbe's kit on my current 10-bolt and then can I STILL use it on my Dana 60/ Corp. 14BFF rear end when I get it switched in? I think all I would have to do is replace the bolt-on axle shock mount...correct?the rest of the system would be good to go, huh?
    Chris
  7. Chaz88K5
    2,979
    Stockton/Lodi CA
    the top part you would use with any axle...the part that attaches to the axle...i am not sure...i know the axle tubes are diff sizes but ask steve frisbe.. i would assume you would need a diff bottom mount but dont quote me on that one.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    yup what Chaz said[​IMG]
    So you save money, updgrade and fix your rig all at once. it does not get better than that my friend[​IMG]
    -zakk
    '77 1-Ton K5
  9. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    My Chevrolet dealer stocks nothing, but he had the shock mount. I am sure the only reason he stocks anything is that he just stocks the stuff that, breaks all the time. Seriously, if you are not ready to relocate your shocks this is a $12 - $13 item that is a pain in the butt to repair, but not $260 bucks worth. I bolted mine on and then had it welded. Less than $50.
    Derf00
    1990 K5 Jimmy 350 Edelbrock Performer TBI, 6in BDS Lift, Dana 60, 4.56, Corp 14B Detriot, 16x10 AE 589's, 37x12.5 SSR
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    You could go either way. Relocate the shocks or replace the mount. I can help with either option too[​IMG] I have the stock bracket off the Blazer. As mentioned previously by zakk I'm making a crossmember for the shock set up.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
