Oh happy day
Discussion in '1982-Present GM Diesel' started by jeffro, Sep 21, 2002.
  1. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I was pretty pleased tody after I cranked up the old 6.2. I charged up the battery and connected it to check my glow plugs with a test light. Only one of them showed good. Well, I wanted to see if it would still run before I drop a load on new plugs so I checked the engine oil, gave it a little shot of ether and wham! she started right up.Mind you, this thing has been sitting in a field with the hood half-way open for a year and a half. Anyway, I've regained motivation to stick it into my 72. Based on some previous posts I should be able to run 40" tires with 3.73 gears and not do to bad, mileage-wise. What do y'all think?
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I run 35s with 3.73s and 700r4 and want lower gears. If you have the 700r4 id go with 4.56, if not maybe 4.10s.
  3. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    I'll be running sm465.
  4. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Hey Jeffro, Where in Dallas are you? Im in Balch Springs. Just moved from Seagoville.
  5. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    Scurry, south of Kaufman. I put Dallas on my profile for the benefit of the geographically-challenged masses.
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Use the AG60 glow plugs. They will never burn out. I don't suggest using the ether too much man. Dangerous stuff!!
  7. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I run 37s, 700R4, 4.10 gears. In drive, it will still cruise just fine at 65MPH. It will pull long hills in second gear at 55MPH. With your 40s I would go with at least 4.10s, 4.56s if you don't do the highway thing too much.
    AC delco 60Gs can be bought at autozone for about $60 a set.
    Ether is BAD. Says so right on my air cleaner.
  8. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    Ether is like crack cocaine for your truck... keep using it and before long you wont be able to start your truck without it... /forums/images/icons/smirk.gif (if it doesn't blow the motor up...)
    Jon
  9. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    To be exact, the AG60 glow plugs at Autozone are $7.99 each! As for your choice of gears, I use 4:10s and get great power with my 33s, but as for cruising on the highway, It hates being above 70!
  10. Txstruck
    May 25, 2002
    87
    Seagoville, Texas
    Where do you take your truck offroad at? There is only one little spot in Seagoville and its no fun by yourself. Shoot me an email and maybe we can hook up one day after it rains! txstruck@aol.com
