OH MY GOD!!!
Discussion in 'The Garage' started by Hossbaby50, Jan 12, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    TPI is AMAZING. It is AWESOME. I got my truck to run tonight and I buttoned it up somewhat. I got it to run and move. I took it and drove it. OH GOD!!!
    I backed it out of the garage into my alleyway (gravel alley). Turned the wheels toward the alley exit and punched it. I spun the tires, the ass end kicked way out and I almost side swiped a telephone pole and trash can. Got it on black top and acceleration was KICK ASS. I can't believe it. The feeling ranks right up there with sex. I am giddy.
    TPI IS THE SH!T. Worth the 4 months down time and every penny.
    Harley
    p.s. Thanks everyone who helped me for your help and guidence.
  2. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Harly I am very happy for you /forums/images/graemlins/thumb.gif, glad to hear it's alive, my truck is another story though...
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    congrats /forums/images/graemlins/thumb.gif sounds like you are very happy with it /forums/images/graemlins/thumb.gif
  4. dyeager535
    26,980
    Glad to hear it. /forums/images/graemlins/smile.gif
    So, thinking of going back to carb for the simplicity then eh?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I hear ya! When I swapped out a tired Q-jetted 350 for the '87 'vette engine I was amazed at the difference. /forums/images/graemlins/eek.gif First time I pulled out of the driveway and punched it the truck laid rubber for at least 50 feet. /forums/images/graemlins/thumb.gif The only way to get it to even make a sound from the 35's before that was to do a neutral drop. /forums/images/graemlins/shocked.gif
    After that one suffered severe indigestion and coughed a rod through the side of the block I "upgraded" things just a bit. /forums/images/graemlins/wink.gif A 383 short block was procured, with a fairly stout cam installed inside. The heads were ported and treated to a 3-angle valve job. The manifold base and plenum were hogged out considerably. A set of Lingenfelter runners were installed, along with slightly larger injectors. Shazam!!! I thought the 'vette 350 was hot, but the 383 blew my mind! /forums/images/graemlins/thumb.gif
  6. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Congrates! /forums/images/graemlins/cool.gif
    Mike
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sweeet!!!
    Thanks for sharing!
    Can't wait to ge my FI454 done!
    Just like sex egh? Man I need to get movin on this project!! hehehehehe /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    When and if I ever go FI, it will be TPI.
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    F.I. Rocks!! there is just no way around it! Congrats on the Upgrade. Enjoy!
  10. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so what did u have to do swap a harness or something? or was ur truck FI befor? sounds fricken awesome good job man!!
  11. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Yes it is. My 406 could break them loose with a Detroit on dry pavement. TPI rocks........ /forums/images/graemlins/thumb.gif
    Um, not sure about the sex comparison but it's pretty rad. /forums/images/graemlins/smile.gif
  12. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Congrats Harley /forums/images/graemlins/thumb.gif I know how you feel. I am actually gonna be pulling my BBC out here in a month or to to start warming it up a bit more...Gonna putsome aluminum heads, MPFI and a much more radiacal cam in it. I am gunning for the 450hp mark. I bought a Jeep Cherokee to run around fort fun in so I can deal with the truck being outta commission for a while...
    On your TPI, did you use an intank fuel pump or do one mounted on the frame rail? How did you plumb the return line to the tank? I will be putting FI on my 71 C10 shortie here soon enough and will have to deal with tsuch issues... Peace out bro.
    Chris
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    write up? pics? tech article?
    j
  14. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Sound great.... I still want to do this upgrade sometime.... congrades on the upgrade....
  15. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    For the return line I spliced a return point into the gas filler neck with a Moroso FI return line kit. It puts the gas back into your filler neck and it runs back into your tank. This was before I realized I already had a return line from the factory. (pays to do homework before you dive into things) The fuel pump is mounted to my body near the rear fender well. I used an external MSD MPFI pump. $90 for a pump isn't to bad. Everything else was $140+. The only problem is it is loud.
    Most of my return line I plumbed threw my old hardlines that fed the mech pump. I plumbed my feed line threw MPFI softline, and threw parts of the old return line or maybe it was the vent line.
    As far as the whole sex thing, this is pretty up there.
    My truck was not previously FI. It was stock Qjet. I had to swap in a wiring harness for the FI system, install (and modify) the intake manifold, injection rails, plenum, runners, throttle body, plumb a fuel system for a 45PSI fuel pump, fuel filters, fuel pump, and of course install the computer, relays, sensors, and wire everything up.
    I used a painless wiring harness (came with my setup when I bought it used) and I used as many stock parts as I could.
    It is amazing the difference.
    As for installing a vette motor, I imagine that would be pretty sick, but I just swapped in the TPI on my old motor and it made a hell of a difference.
    Harley
