ohm reading on primary resistance wire to coil
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by GlenYappa, Aug 21, 2003.
  1. GlenYappa
    GlenYappa Registered Member
    Jan 31, 2002
    11
    I have a '72 Blazer. Does anyone know what the ohm reading should be on the ignition wire? I'm having to replace some wiring and I went with a normal wire and need to know what ohm ballast resistor to get.
    Thanks,
    Glen
  2. grunt11b40x
    grunt11b40x 1/2 ton status
    Mar 1, 2003
    124
    winston salem, nc
    should be 12v to the ballast and around 8ish from the ballast to coil if i recall correctly, any parts store should be able to set you up with the right one it's a pretty standard part for a point set up
  3. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    Before I went with HEI, I was using Mallory P/N 700 ballast resistor.
