oil additives in clutch type rears?
Discussion in 'The Garage' started by sweetk30, Feb 26, 2006.
to add or not is the question?
Poll closed Mar 5, 2006.
  1. will wrok fine
    0 vote(s)
    0.0%
  2. will not work fine
    3 vote(s)
    50.0%
  3. i am naked and covered in oil additives
    3 vote(s)
    50.0%
  1. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i have over 100k miles on the daily driver. she is whinning in the rear at some speeds and it also has a govbom rear. i was looking at adding lucus oil additive to the rear to help the rear out. but will this hurt the clutches or not is my question.thanks.
    more info down below.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Most additives allow the clutches to slip to avoid chatter.
    If your rear end is howling than an additive is not going to help . Most likely the Gov-Loc is dying a slow death and the small part are wearing down and getting caught in the bearings and wearing them out with every turn.
    If you need it to last as long as possible than put some 140 weight gear oil in along with the GM additive and drive easy when turning sharp corners ( as in little to no throttle ).
    HTH's Tom
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Gov loks take no additive. Do not use a friction modifier.. Just put in 140 wt oil and change reguarly.
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Very true ! Just wanted to give him advise on making it last, if it is possible . If the G/L is wearing out than the additive might help the clutches slip instead of grip like a functional G/L.
    Tom
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Ahh yes I see the method to your fix. The care and feeding of a gov bomb:D
    They have to be carefully prepared so they will detonate properly.:laugh:
  6. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Ha ,ha !
    I would say that GM/Eaton should be ashamed of such a creation but the designer probably got a bonus due to the amount of additional Gov-Bombs sold throughout the years ......
    Tom
  7. sweetk30
    Nov 1, 2004
    25,536
    533
    na the gov bom has only around 20 k on it. and works great. sounds like bearing howlling.
  8. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    if its bearings that I'd look at your wheel bearings to start.
  9. sweetk30
    Nov 1, 2004
    25,536
    533
    na looked good few months ago. when at speed if you load and unload the drive line with the gas pedal it makes the noise more under load. and its a 96 cc long bed 350/4l80-e/14ff
  10. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like your pinion bearings. They are just getting worn. Not bad. 140 wt will quiet it down a little. There is a little slop and the gears are making a little noise. Should last quite a while with care. When it quits howling and makes growling noises then its time to worry.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah bad beairngs. A rebearing is an easy job, espically on a 14 bolt. DO a pattern and backlash check to make sure the R&P are good. Then take it apart, change the carrier beairngs, and pinion bearings ( I reccomend taking the pinion sub carrier to a shop where they can crush the sleeve for you), put it back together and set the backlash to what it was before you took it apart.
