Oil and Filter
Discussion in '1982-Present GM Diesel' started by guard66s, May 25, 2004.
  1. guard66s
    guard66s Registered Member
    May 24, 2004
    8
    SLC, UT
    What oils and filters do y'all use? Ive been using Napa Oil Filters with delo 400 15w 40, but i recently switched to Mobil 1300 15w 40, and my truck seems to run smoother longer on it, im curious as to what oils and filters evryone else uses, i do an oil change bout evry 1750-2000 miles. /forums/images/graemlins/whistling.gif /forums/images/graemlins/k5.gif
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I use the purolator filters and Valvoline or Castrol 15W40. I change oil every 3000 miles...
    I recently bought the larger 2 quart oil filter, then found out it won't fit without modifying my exhaust. /forums/images/graemlins/doah.gif
    I'll make sure I have enough room when I install my Hummer headers and get new exhaust done. It'll be nice to use two 4 quart jugs of oil without anything left over, and the extra filtration won't hurt any either.
    Rene
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I just switched from Rotella 15w40 to the Synthetic rotella (5w40 I think). The truck seems to run smoother, I know my oil pressure at idle dropped quite a bit. Its in the same spot when Im driving, but I expected as much from the other cars I switched to synthetic since its flowing is much better than regular oil.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I was thinking of switching to the synthetic rotella too but at 22 gal per oil change I guess it's better to stay with the 15w40.
    I use the NAPA filters too and I have 2 big filters on mine 1 quart each.
  5. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Yeah, it certainly is a bit more costly. Cheaper than delvac 1 though. Dunno how much of a performance gain/protection im acutally getting, but I'll try it for an oil change, and then maybe go back to using the old stuff for the summer, and synthetic for the winter.
  6. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    whats the 2 quart filter part number? Is it larger diameter, longer, both?
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
  8. guard66s
    May 24, 2004
    8
    SLC, UT
    The diesel 2 quart for Napa Gold filter is 1794
