oil and fuel filter change
Discussion in '1982-Present GM Diesel' started by alec78, Feb 11, 2003.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Changing oil for first time. What type of oil should I use? I've heard not to use multigrade (5W-30) on a diesel, but I could be mistaken. How much oil does a 6.2 hold?
    Also, where is the fuel filter?
    Thanks,
  2. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    Rotella-T, the only way to go. Takes about 7 quarts if I recall correctly.
  3. Why me?
    Why me? Registered Member
    Jan 28, 2003
    22
    A girl at a deli that I used to go to was named Rotella. Seriously, I use the Rotella T, even in my lawnmower.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I also use Rotella, but now you are going to start a new thread that went for weeks.
    Do a search (it was about a couple of months ago and I am sure a few before that)and you will find basically 3 brands that most people will agree on.
    /forums/images/graemlins/thumb.gif
  5. 4x4dreamer
    Jul 8, 2002
    874
    St. Petersburg, FL
    and to cover all the bases before the fertilizer hits the ventilator, all 3 are good oils. My preference is the Rotella-T. I'm not saying it's the only Oil you should use, it's just what Me, Myself recommend and have been recommended. I have been told some Big rig manufacturers will void their warranties if you use anything BUT Rotella.
  6. Can Can
    15,555
    151
    Cochrane, Alberta, Canada
    I personally use ACDelco 15w40. I usually use Delco filters too.
    Whatever oil you choose to use, make sure that you change the oil and filter out every 3000k max. There has been lots of discussion on this topic, and it seems that the factory service intervals aren't frequent enough to keep your 6.2 running top notch.
    Also consider using Stanadyne fuel conditioner due to the new low-sulphur diesel that is available nowadays.
    Welcome to CK5 diesel club, brother!!! /forums/images/graemlins/thumb.gif
