Oil capacity, best oil, and oil filter for a 6.2L?
Discussion in '1982-Present GM Diesel' started by AJMBLAZER, Mar 21, 2002.
  1. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    What's the oil capacity of a 6.2L?
    I'm assuming whatever truck this guy finds for me will be the stock setup.
    What's the best oil to run in a 6.2L?
    What's the best oil filter to run on a 6.2L?
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    7 quarts with standard 1 qt. filter.
    I use Rotella T 15W-40 dino (regular non-synthetic) oil. This is a good oil designed for diesels. Whatever you use, make sure it's rated for diesel engines. It will have the C rating (for compression ignition) as well as the S (for spark ignition) rating.
    Use any filter you want except Fram....they're not much better than a piece of toilet paper. I read an article where they cut open all the major brands of oil filters to see what was inside. Fram didn't have much at all. I prefer Wix. Baldwin, AC Delco, and Amsoil are good as well.
    Change the oil religiously. You'll notice the oil will turn black almost immediately after you change it. This is due to soot getting past the rings. I change mine every 2500 to 3000 miles.
    Casey
  3. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I end up putting in 8 quarts but I use the 2-quart oil filter, available at most auto parts stores.
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I use K&N oil filters. I don't think it matters with the Diesel...it comes out black as the ace of spades anyway!!!
  5. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    I take my truck to a Valvoline oil change station (live in an apartment, no garage... *sigh*), and I get their partial synthetic for diesels called Super Blue 2000. I can't remember what filter they normally put on, which is something I'll have to look into. I know it's not Fram.
    At any rate, the previous owner used nothing but Shell Rotella. After I switched to the Valvoline synthetic blend, I've noticed my truck seems quiet down after a cold start very quickly, even when it's cold out. I like the stuff.
  6. AgDieseler
    AgDieseler Certified Scrap Producer Premium Member GMOTM Winner
    Jan 25, 2001
    1,040
    1,108
    Dallas
    Friends don't let friends use Fram.
  7. BADASSBLAZE
    BADASSBLAZE Registered Member
    Jul 20, 2001
    63
    Pollock Pines, California
    My K5 has a 7 quart oil pan and I always use Chevron Delo 400 Multigrade motor oil with a Wix oil filter. I change the oil every 2500 miles.
  8. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    All are talking about FRAM. Is it the model PH13?
    I must use different oil seasonally. In the summer 15W-40, in the winter 5W-30 is necessary. I pay attention to the Diesel specification and change all 5000 mls.
    The capacity of my engine is 7.4 quart, without filter.
  9. arveetek
    Mar 1, 2002
    722
    Yes, the Fram PH13 is at the very bottom of the list, and is really not worth using. Almost every other filter out there is better than the Fram.
    Casey
  10. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Thanks, is good to know.
    What is the best filter in your opinion?
    With you in the USA there are relocations kits with two filters. What do you mean of it? Does that have any advantages?
  11. Danno
    Aug 4, 2001
    487
    Rockford, IL
    Check out this site:
    <a target="_blank" href=http://216.239.51.100/search?q=cache:rLvSVxdi_WoC:www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html+Oil+filter+comparison&amp;hl=en>http://216.239.51.100/search?q=cache:rLvSVxdi_WoC:www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html+Oil+filter+comparison&amp;hl=en</a>
    The link is hideously long, and the site appears to be down for the moment. This is a link to a cached page on Google. The links I've tried off of that page seem to work OK.
