Oil Change on a rebuilt 350?
Discussion in 'The Garage' started by mcvaaahhh, Nov 2, 2004.
  1. mcvaaahhh
    mcvaaahhh Registered Member
    Nov 2, 2004
    5
    Lakewood, CO
    I just bought and 85 blazer with a rebuilt 350. It's got about 17K on the rebuild. I need to do an oil change so I just have an easy question. What oil should I use? I put 5w-30 in my 2000 f-150, should I use the same, or 10w-40 or what?
    I'm going to be using this as a daily driver.
    Thanks for the help.
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    With only 17k on the motor I'd start using a synthetic oil. And use a good quality filter too, like a Wix. Don't use those cheap Fram filters.
  3. mcvaaahhh
    Nov 2, 2004
    5
    Lakewood, CO
    thanks for the info.
    Where do I get a wix filter from? /forums/images/graemlins/ears.gif
  4. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I prefer Valvoline, and I've always used 10W-30.
    I'm not sold on synthetic yet. My engine builder recommended using regular oil and changing it every 2000miles.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Dont use 10-40. 10-30 if fine or 5-30 if it gets real cold where you are at. I guess synthetic oils are good if you want to spend a bunch of money every time you change oil.
    I use them in my boat and in a car I have a Turbo on. But for my Daily drivers I like regular 10-30. I just cant see how syn oils costs are worth the small benifits they give.
    Wix, Purloator, or AC delco, are all very good filters. Fram sucks.
    You might also think about doing a trans fluid change/filter. Espically if you have a 700r4.
  6. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Use 10W-40 I have found that my engine just burns 10W-30. By the way my engine only as 10,000 miles on it.
    Adam
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I use 5w-30 in mine. /forums/images/graemlins/thumb.gif
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i use 10w-30 in the summer and 5w-30 in the winter. /forums/images/graemlins/waytogo.gif
  9. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i use 10-40 in all my vehicles.
    except for my sandrail , that i use 20-50
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I'm runnin right now,,,straight 50wt, 217,000 miles on the 350, don't recommend doing this in colder climate states though. /forums/images/graemlins/whistling.gif
