Oil coming out of the distributer?
Discussion in 'The Garage' started by big dan, Dec 20, 2005.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Has anybody heard of oil coming out of the distributer? I've replaced my intake gasket twice and i've fixed my oil pressure sending unit. I'm still leaking oil and it looks like its coming from the distributer.
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Is it coming out at the base where it mounts to the intake? cause theres a gasket there that can fail, or is it actually coming from under the cap ?
  3. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    I have the same thing!It looks like it's coming from up at the intake but can't tell for sure,it drips off of the starter and the oil filter.I am taking the intake off and replacing the intake gasket,dist. gasket,and pressure sender.Let me know what yours turns out to be.
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Check the gasket that seals the base of the dist. with the intake.
  5. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    its coming out of the base. ive replaced the gasket both times i changed intake gaskets.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    you need to look at the gear on the distributor and make sure that the gear isnt bottoming out on the cam gear and keeping the distributor from seating properly. If by chance it is then you will have to determine what size shim you need and shim it up.
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Check the brass tee that comes off the block next to the distributor for your oil pressure sensor. Mine was leaking and it traveled exactly like you said to the ground.
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Hmm, I don't think I have a gasket on my dist. I wonder if that's why it never really tightens down? :confused: :crazy: :doah:
  9. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Would a Bad PCV valve cause this?:dunno: Just a thought.
  10. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    thats one of the first things i checked. i even bought a new one just in case. it doesnt leak all of the time only when the motor is under a heavy load. would it hurt to put a little silicone on the gasket around the base?
  11. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Also check the rear intake manifold gasket. Don't use the rubber end pieces, use RTV or "The Right Stuff."
