Oil cooler elimination???
Discussion in 'The Garage' started by Bigdawg234, Nov 27, 2006.
  1. Bigdawg234
    Bigdawg234 Registered Member
    Apr 11, 2006
    29
    Leechburg, PA
    Ok I got a 1990 k5 and i keep smashing that stupid oil cooler, or ripping a line off it every other time i go wheelin. Most of the damage is due to running in thick brush/small trees(private property, its gettin cleared anyway). And its hard as hell to find the coolers/lines. I just want rid of the thing, so my question is, does the adapter that has the lines coming out of it just come off and then i can put the filter on like normal, or do i need the adapter off a regular small block?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You need the adpater off an earlier non-oil cooler engine.
  3. Bigdawg234
    Apr 11, 2006
    29
    Leechburg, PA
    ok, i got a 305 i can steal it off of, I just wanted to check before i tear into it. thanx
