Oil Cooler Leak ?
Discussion in 'The Garage' started by Mr.Selfdestruct, Dec 1, 2005.
  1. Mr.Selfdestruct
    Mr.Selfdestruct Registered Member
    Jun 16, 2005
    14
    Tulsa, Ok
    This morning i drove to the gas station to fill the ole suburban up, and when i got out of the truck i noticed a stream of oil that was behind my truck. i followed the stream to a huge puddle under the truck, the oil was pouring out of my Oil Filter and or Oil Cooler . Is this a common problem ? Is there a gasket on the oil cooler somewhere? I had to park the truck and take another vehicle to work. The truck is still sitting at the gas station, waiting for me after i get off of work, SO i havent actually pulled the filter off the truck yet, but in the case that its not the filter and it is the Oil Cooler, any tips would be appreciated.
    -Tim
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    was it leaking were the oil cooler lines come out of the oil cooler adapter on the block? They use some crappy connectors there that can be leaking.
  3. Mr.Selfdestruct
    Jun 16, 2005
    14
    Tulsa, Ok
    Actually it looks to be leaking directly above the Oil Filter itself.
    -TIm
  4. dyeager535
    26,980
    The oil cooler lines thread into what appear to be brass fittings, which thread into the aluminum filter adapter.
    It's likely that the line(s) started leaking right where the line meets the fitting. The rubber hose style oil cooler lines are much poorer construction than the earlier braided steel lines when it comes to leaking at the fittings.
    You can have new lines made up at hydraulic shops for much less than what new lines cost from GM if it is the issue.
    It shouldn't be too tough to crawl under the truck, start it, and see where it's coming from. There is an o-ring on the adapter as well, that potentially could go bad, or your oil filter seal could have blown out as well. Need to look at the truck and see what can be figured out from that.
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Check the lines themselves. They sit on top of a frame cross member and can rub right through the line over time....causing your exact situation (which I have experienced on the side of the road late at night in freezing temperatures).
  6. Mr.Selfdestruct
    Jun 16, 2005
    14
    Tulsa, Ok
    Ok i'll be sure to check both the line and the filter/filter adapter.
    Thanks again
    -Tim
  7. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    thay use a geasket and oring to seal the adaptor to the block.
  8. Mr.Selfdestruct
    Jun 16, 2005
    14
    Tulsa, Ok
    Ok, i turned the truck on, got underneath it, and felt around and i it looked like the oil was coming from inbetween the block and the Oil Filter Adapter, directly above where the two steel hoses and fittings attach.
    So i pulled the filter, and removed the two allen bolts and droped the oil cooler assmbley, and i could see half a gasket and i couldnt find an o-ring, and on the lower part of the filter assmebley that touches the block, it deffinately looked like there should have been an O-ring there. So im gonna pick up a gasket/O-ring kit at the local chevy dealership and hope it fixes the problem.
    Im just thankful i was able to notice the huge leak before i seized the motor on the highway!! :eek1:
    -Tim
