Oil cooler line keeps blowing off!
Discussion in 'The Garage' started by 86haubs, Nov 1, 2006.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    This is the 3rd time this year it has happened to me, I would like to see pics of some other members setups to see what I am doing wrong.
    I am actually running a trans-cooler for my oil. Is this a problem? I have a 5/8" rubber line coming off the factory oil lines, going through a reducer to the 3/8" rubber line for the cooler. I didn't have time this morning to look at it and see exactly what happened this time, but I need any help you guys and gals can offer.:mad:
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    What kind of hose clamps are you using? I would recommend using one of the fuel injection hose claps (Ideal makes them). They look to be a bit stronger.
    Are the ends on the cooler side barbed to use with a hose clamp?
  3. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    All places where my lines hook up are barbed. I was told that oil coolers have a dual barb fitting, opposed to my single barb. I am just using standard hose clamps, I am pretty confident that the hose clamps are not the problem. But who knows?
  4. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    You can try double clamping the connections, but when you reduce the size of the lines, the pressure on them is going to go up.
  5. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I think I am going to buy an "oil cooler" and ditch the "trans cooler" I am thinking this might be the problem because the cooler can not offer the flow I need when the engine is cold and I think this is the problem. What do y'all think?
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    I'd say..
    I'd use an oil cooler for motor oil,and a tranny cooler for a tranny or P/S cooler...I think 3/8" is too small for the volume of oil the oil pump can push,and its causing a pressure build up,that eventually blows the hose off..the fact your reducing a 5/8 hose to a 3/8 hose raises the pressure, and reduces flow rates,and is likely your trouble...
    All the factory oil coolers I have seen have at least 1/2" I.D. hoses and tubes in them..:crazy:
  7. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Thanks for all the help. I guess that is what I will have to do. I never thought about doing a P/S cooler, how would I go about doing one?
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Get hard lines or have oreilly's make you some hydraulic lines you can use.
  9. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    That trans cooler isn't up to the job at all. Never step down in hose/tube size from stock. Can step up in size. Go with either a stock engine oil cooler found on those vehicles with the tow option or use a cooler designed to be used for engine oil. Can get them from circle track vendors like Port City, Coleman, AFCO, etc.
    On the PS cooler thing, just put a small trans sized cooler in the return hose.
    & speaking of hoses, look into the "Push-Lok" or "Barb-Tite" type of hose fittings. They have 2 barbs and are difficult to push the hose over. This type of hose end, when used with the correct hose, is good to way above normal engine oil pressures w/o a hose clamp at all. In fact, putting a clamp on them usually cuts the hose & causes a failure. If going barbless bothers you, then after they are assembled put a tie-wrap over the hose btwn the barbs. Cinch it down snug, but not tight.
  10. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Dude, the pressure going to 3/8" is doin' it, you need 1/2". Factory lines are at least that.
  11. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Hose clamped lines are not something I'd be messing with on oil lines.. Good way to pop a motor...
    Do the Push-Lock or better yet, make some up with reusable AN fittings...
  12. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Well 130 bucks later the Burb is running like a champ. The hoses I pulled off were completly shot! They were expanded almost twice the normal size, the inlet line finally let go this morning. It never really crossed my mind that the trans cooler wouldn't work. I didn't even think about it because this truck was so jimmy-rigged when I bought it. I am working these problems a little at a time.
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Hydraulic lines would be the only thing I'd use. You can have them crimped, or you can buy the reusable fittings.
    Or do like I did - ditch the cooler altogether and plug the block. :D
  14. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    I think I would rather take my chances having one, than not having one.
    I was thinking back, I think I know how it blew. I went mudding this weekend and got stuck, bad. I was on it pretty hard, I bet that is when i got the hole in my line. WHOOPS! AH, it was worth it!
