OIL cooler question about 90's pickup setup on 80's K5
Discussion in 'The Garage' started by jjlaughner, Nov 13, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OIL cooler question about 90\'s pickup setup on 80\'s K5
    Will a 90ish truck oil filter adapter fit on my 87? It mounts to the filter location and drops the filter down about an inch, it has two hard lines that run up front.
    My dad has one on his 93 pickup I thought about getting one and try putting it on my blazer. /forums/images/graemlins/thinking.gif
  2. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Re: Tranny cooler question about 90\'s pickup setup on 80\'s K5
    BTT
  3. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    i'm not too sure on the oil cooler/old tranny cooler setup. i don't think it will work.
    the newer oil cooler adapter should work fine for your 87. my 87 came with a factory auxilary oil cooler and i bet it real similar to the early 90's. i hope this helps.
  4. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Re: OIL cooler question about 90\'s pickup setup on 80\'s K5
    If you are talking about the factory installed oil cooler then yes it will bolt up to your engine. Some blazers came with the factory oil cooler installed, my "89" has it factory.
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Well....depends on what year the oil cooler is from. I just had to deal with this putting a '95 block in an 87 suburban. Basically 87 cooler/95 block. The 1987 uses an adapter where the lines go into that. The lines come from the cooler and go the fittings are STRAIGHT to go into the adapter.
    On the later models...the lines go directly into the block, so they have a 90* fitting on them. So I dont see how they would just screw into the earlier adapter.
    I had to get some conversion lines from GM for this purpose. They bolt right up to the 1987 cooler...and then have the fittings to go into the block rather than the adapter.
    Make sense?
    Oops,, just re-read your post...it sounds like you already HAVE the adapter. So yeah it should work. On the later blocks they dont use the adapter so you cant screw one on, the blocks werent cast that way. You have to run the lines directly into the block parallel to the oil pan rail.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Sounds like it will work fine. I had that setup on my '82 untill one of the lines blew on me. Then I decided that it wasnt worth it.
  7. dyeager535
    26,975
    Blocks are the same, not sure why it wouldn't work. Maybe you can get your local chev dealer to cross reference the part number for that adapter for your year truck, and the year donor you are dealing with.
