Oil Cooler
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer_87, Oct 3, 2001.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    I have an 87 Blazer, I just bought it and noticed that it has an external oil cooler. I was wondering if that was standard or an add-on.
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I believe that was a stock option. even my bare bones scotts dale had this in it.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah it was a stock option. It was usually included in the "Towing Package"
    My 89 was orderd with the towing Package and it came with a oil cooler and a trans cooler.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  4. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Mine has the oil cooler also. 88. Wonder if it hurts to get rid of it?
  5. dyeager535
    26,980
    Prolongs the life of the oil, (by keeping it cooler) so I'd assume it would be harmful to remove it. But thats probably an immeasurable difference, since the majority of vehicles produced don't have external oil coolers.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  6. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    I wouldn't pull it unless the hoses looked worn. Probably check with a mechanic to. To me it's just one more thing to break and have my oil presure goto zero!
  7. dyeager535
    26,980
    Not sure when they did it, but I would be somewhat concerned of the later ones popping, that look like power steering hoses. The earlier ones are steel braided, and there is no way they are going to pop. At most a hefty leak, even then I consider that damn unlikely. I do not like the power steering style ones, my friends '83's leak like a sieve, and miine are older.
    Dorian
  8. dyeager535
    26,980
    Not sure when they did it, but I would be somewhat concerned of the later ones popping, that look like power steering hoses. The earlier ones are steel braided, and there is no way they are going to pop. At most a hefty leak, even then I consider that damn unlikely. I do not like the power steering style ones, my friends '83's leak like a sieve, and miine are older (braided) and do not leak.
    Dorian
    My tech/links page: &lt;a target="_blank" href=http://www.dorianyeager.com/index2.html&gt;http://www.dorianyeager.com/index2.html&lt;/a&gt;
  9. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    My 77 has the same external oil cooler and it has never given me any problems. I would leave it on. The GM engineers didn't spend all day designing it if it wasn't worth a dam. I beleive it helps to keep the engine temperature down too. If it aint broke don't fix it.
