Oil cooler
Discussion in '1982-Present GM Diesel' started by Tybee, Jul 7, 2002.
  1. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Looks like one of my oil cooler lines might be leaking right behind the shroud. Havent taken the shroud off yet so im not sure where the leak is. Anyone ever replace these lines before and know how much they cost? Or any one have one around?
  2. pavo
    pavo Registered Member
    Jun 16, 2002
    17
    Denver, CO
    yep, easy to replace, just did one last week. expensive though. could only find the part from the dealer. if you look at the end that goes into the radiator the upper one is about $85 and the lower one is $104
    i have a 82 6.2 k5 blazer
    here is the GM part numbers i used
    upper: 12472186
    lower: 14036781
    the lines i got did not include the right angle into the cooler though! that must be a different part number.
  3. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    /forums/images/icons/shocked.gif Damn thats a lot. Did yours leak.
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Also can you bypass the radiator.
  5. pavo
    Jun 16, 2002
    17
    Denver, CO
    yea, mine leaked at the engine though. i think you mught be able to buy those 90 degree ends that do into the radiator separate though. i don't think you want to bypass the radiator. my engine has enough trouble cooling when the heat hits high nintys and its working hard
  6. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Must be a diffrence in the years, mine is 1 piece from the hose to the radiator. $31 from the dealer.
