oil disappearing
Discussion in 'The Garage' started by shaun89, Apr 27, 2006.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    my friend has a 454 and it burns a tiny bit of oil when it starts, then after that, it just smells like a 454 with no cats. i dont see any oil burned even when he floors it,and the engine doesnt have any oil on it anywhere....it takes 8 quarts and almost all of it has disappeared in about 3 monthes.:doah:
    i searched for this also.
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Could be valve stem seals. Has he pulled the plugs to compare colors/deposits?
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    sounds normal typical for an old high miles engine
    i wouldnt worry unless the plugs are black oily or youre having to add oil often
    but it needs at least stem seals replaced, if not possible guide replacement on a few valves,
    but if it runs great and strong still then i really would not worry, unless you loe ot part with $ when its not totally required
    but if its just a tiny bit only at startup then theres no worry needed at all
    good luck
  4. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    no he hasnt pulled the plugs to see the colors...but ill let him know, maybe we'll do that today, thanks:waytogo:
