Oil drain plug stripped
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex, Apr 29, 2002.
  1. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    Does anyone know the size and threads on the oil drain plug bolt for a 350? The person I bought my ‘91 rig from was servicing his oil changes at the local siphon club and they stripped the threads on the pan. They installed a generic plug that I want to get rid of, so I need to re-tap the threads in order to go back to OEM. Thanks in advance.
  2. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    When I striped mine I went with an oversize one that I bought at autozone. orignal is 1/2 20(fine thread, I might be wrong on 20, it might be 18) and oversized 9/16 18
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i think they make a kit for this problem but i would use this as a reason to get a new BIG oilpan HEHEHE /forums/images/icons/smile.gif
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Or if not a oversize pan then one with the skid plate welded on the bottom for more strength.
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    FU(|< it, a big one with a skid plate. but i dont see how a person could put the oil pan on a 4x4 in to a rock without other problems to...
    grant
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    If you roll over a tree limb and your left tire rocks it up into your oil pan. Or you spit a rock up into your oil pan.
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Go to your local parts store and ask them for a oversize drain plug. They come in a 1st oversize, 2nd oversize, and a 3rd oversize. Once you have used the 3rd oversize then you replace the oil pan.
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Go to your local parts store and ask them for a oversize drain plug. They come in a 1st oversize, 2nd oversize, and a 3rd oversize. Once you have used the 3rd oversize then you replace the oil pan. These oversize drain plugs by the way are self tapping.
