oil drainage?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Jun 6, 2002.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    a while ago, i heard about an adapter that mounts up to your oil pan that makes a 90 degree angle. it replaces the oil pan plug and supposedly makes it a whole lot easier/cleaner to do an oil change. anyone know where i could find one of these convenient doo-hickies?? thanx in advance.
  2. flyndragons
    flyndragons Registered Member
    May 28, 2002
    18
    Finally back in the US!
    Try checkin Jeggs or Summit Racing. I'm pretty sure they have them. They are very nice, but like catching rocks.
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    wal mart has them.
    NITRO
  4. dyeager535
    26,979
    Fram sells them now, but the outlet is like 1/4" and the hose that comes with it isn't long enough to reach the ground. At $15, very small (slow) orifice, and still having an oil filter leaking when you remove it, I decided not to use one. Besides, it's just something else that can fail.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Plus it's made by Fram.........../forums/images/icons/tongue.gif
  6. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    Those fittings make it easier to change oil, but I don't use them because I like to use a sucker gun to draw out the puddle of oil on the bottom of the pan. With a little hook shaped copper tube, I can get a half- pint of nasty stuff out of the bottom of the pan where the solids settle. Seems to me to be an important part of oil change.
  7. dyeager535
    26,979
    Well, I didn't want to start anything with that lol. : )
