Oil filter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Sep 13, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Is it not a good idea to change the oil, filter you have been using... cuz the preious owner took it to walmart each time he changed the oill. They used the cheap filte rand oil. Would it not be a good idea to switch to a dif type of oil/ filter?
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, rear springs , Throtle body spacer.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    No problem to switch - it'd be a concern if it had always had synthetic before, but switching up doesn't hurt.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    technically, if he didn't run detergent oil you shouldn't either, but non-detergent oil is difficult to come by, so i would ASSUME that wal-mart doesn't have it.
    Tork DSR
    I just got a winch, it takes the fun out of things.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I work at a Jiffy Lube, and I don't know about the guys at Wal-Mart, but I'd absolutely refuse to service a vehicle if a customer demanded non-detergent oil and brought it with them. I'd politely show them the door on the opposite side of the shop from where they came in, and ask them to drive through it.
    Tim
  5. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    why. switching from detergent to non-detergent does nothing for the car, the environment, the cylinder. actually the crud buildupp helps to keep things seeled up, honest. i work at a parts store.
    Tork DSR
