Oil filters......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thatK30guy, May 17, 2001.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    what is the best brand or your favorite that you use? I use Fram filters.
    When In Doubt, Whip It Out!
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    AC Delco
    90K5
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I use Fram Tough Gard or the AC Delco Gold (depending on the phase of the moon)
    '71 Blazer CST with alot of rust
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Frams are the worst. I used to get bored at an oil change place I worked at and cut old filters apart and see how much paper there was and the general construction of it. The bottom of the line was Fram. Very little paper and the element was glued to the canister. The AC-Delcos and Motorcrafts were next up on the list. They had more paper and tighter pleats. By far the best though were NAPA Gold and WIX filters. They are kinda pricey, but the had very good constuction. The canisters were very strong and the element had the most pleats and by far the most material. So I would say either NAPA gold or if your cheap (like me) get the AC-Delcos. Anything but Fram IMHO.
    '82 K5 6.2 Diesel, sm 465 np 205, 35" muds
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I use Fram on the Truck (like the gripper)
    And th AC Delco UPF series on the Vette. Use this cuz it matches all filtering criteria plus pressure/and volume stats. The vette guys suggest that.....
    Kinda expensive.
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I use wix on anything I really care about... such as my racers and newer motors. My Blazer gets AC Delcos cause I think they are fine for regular everyday drivers, plus the motor is gonna get plucked soon enough anyways
    1987 Chevy K5 Blazer- 350 TBI
  7. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Im with BlueBlazer on this one, The Napa Gold filters are made by WIX, and are exactly as he described. The only good thing about the Fram filters are the grip stuff the dunk'em in . That is kinda handy.
    Stick with the NAPA GOLD / WIX
    STOLEN '89 K5 - 4" lift. Found in Compton
    stripped and dismantled.
    This site rocks!!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  8. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    There was a very good (and long) post about filters a couple months ago...I think it was this site....may have been OffRoad.com...anyways...some guy had found an engineering study about filters,etc....Mobil One filters came out on top....AC Delco was mentioned as being OK, as well as Wix.....the information about Fram scared the hell out of me....I won't use Fram if you pay me.....I use the Mobil One filters exclusively on my Vette, and I use the AC Delco on my Jimmy since it has 114K on it.....I change the oil religiously in both vehicles as I always have....the Vette has had Full Synthetic since new....I use a blend in the K5...when I swap in the new motor, I'll use Dynojuice for about 5K for break in, then switch to Synthetic.....one thing for sure, I'll Never use Fram.....I'll try to find the post ...lots of enlightening information there....just adding another opinion to the mix....JD
    I'm at 10th and Plum....10 miles from nowhere, and Plum out in the sticks....Stuck?...Hell no..I still got some gas left..
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I like AC Delco Its the brand I have always used in all my GM vehicles. But I like to put a Wix on during hunting season because that is when I use my Blazer the hardest and put many hunderds miles of hard dirty dusty driving on it.
  10. 85k5blzr
    85k5blzr 1/2 ton status
    Jan 10, 2001
    103
    Houston, Texas
    I know the only reason i use fram is because i am ignorant about filters and because i can get them at the O'Reilly 1 minute from my house, looks like i'll be changing though
    K5 just upgraded to rig status! [​IMG]
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Lately I've been using the Purolator PureOne filters on the Blazer and Eclipse.
    Here's a few interesting links. Through a stroke of pure genius... well maybe just dumb luck... I wrote down the URL's for this info. Here they are:
    http://members.nbci.com:80/minimopar/oilfilters.html
    <A target="_blank" HREF=http://members.nbci.com:80/minimopar/oilfilterstudy.html>http://members.nbci.com:80/minimopar/oilfilterstudy.html</A>
    Good info here... I stopped using Fram and told everyone I knew to stop too.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
  12. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    AC delco 1218.
  13. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I don't know if I saw the same article exactly you did, but I saw one in I believe it was February about the filters. You're right about Fram. I remember they sucked. I had one at the time I was like ok this thing is going buh-bye! I like the wix ones...K&N makes filters em now too right? I was considering buying one to check it out....for now the wix is what I run unless I find one better I like....
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
  14. 77GMC15
    77GMC15 1/2 ton status
    Mar 14, 2001
    110
    Vacaville, CA
    I'm putting a new rebuilt 350 in my truck and the guy that lives accross the street from me works for NAPA and does things with the racing truck. He says he has blown an engine from a FRAM oil filter. He suggested WIX to me with a remote link to the filter so it can be in a place by itself and not be damaged.
  15. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I use Purolator, but I also heard Wix is great. Yea, Fram sucks pretty bad.
    '73 K5
    Chevy good...Ford bad
  16. shane
    shane 1/2 ton status
    May 6, 2001
    162
    Prince George, BC, Canada
    When you purchase an oil filter you need to know how small of a particle you want to filter out. A good rule of thumb is 10% of the clearance. If you have .010" clearance you would want to filter out everything down to .001" or 25 microns (or is it 2.5 microns?). You have to ask yourself how fine of a sandpaper you would allow to be run in your motor.
    I was checking out the K&N and they said on the box that they filter out down to 20-30 microns. I`m not sure what my clearnaces are so I`m not sure if that is acceptable. I still need to do a little investigating.
    Make an informed choice. I was also thinking of running a diesel fuel filter that is good to filter out down to 2 microns. I wonder is that would help maintain the injectors?
    Shane
    Just keepin it Canadian[​IMG]
  17. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    NAPA Gold for sure. It's the same old story. You get what you pay for.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 Vortec stroker. Build it Bulletproof and take it fishing!
  18. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I use WIX on the Blazer and the Elco. My guy that built the engine for my Elco uses them on everything and highly recommends them.
    <P ID="edit"><FONT SIZE=-1>Edited by 90blzr on 05/18/01 04:36 AM (server time).</FONT></P>
  19. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i used to use a AC DELCO
    but now i can get a deral on a K&N for the same frice as the others.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  20. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    I use WIX on the Blazer and Purolator on the 4Runner.
    Scot in KC, MO.
    Black 87 Chevy K5
    Red 86 Toyota 4Runner (for sale $2000 obo)
