Oil gauge pegged at 60+
Discussion in 'The Garage' started by scoutillac, Apr 28, 2004.
  1. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    As you all probably know the burb sucked H2O and is smoking like hell. So I ordered up some parts for the rebuild. Someone told me because the air filter was wet it created an extreme amount of vacuum and sucked a valve. But now the oil pressure guage is throwing a fit. Does anyone know why all of a sudden my oil gauge is pegged out above 60 when the rig is on or off?
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    never seen that before. try removing the sender and cleaning it /forums/images/graemlins/dunno.giflet us hear what you find
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Make sure that the wire going to the sensor is connected.
  4. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Mind did that just last week. Replaced the sending unit and life was good again.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if the wire grounds out, IE melts ot exhaust manifold then it will peg the needle, search for and follow the singel dark green wire on driver side cylinder head in between the first and second cylinders, have someone watch the needle with igniton key on while you trace and move wire around,
    none of this has anything to do with it having been burning water
  6. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    I'll look there tomorrow. /forums/images/graemlins/waytogo.gif
  7. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Dang, I feel bad that our water hole caused all this hassle and damage. /forums/images/graemlins/blush.gif
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Do you mean it reads 60 at all times? Mine always reads like that /forums/images/graemlins/thinking.gif Is that not normal? I thought it was /forums/images/graemlins/thinking.gif
