Oil Gushing from Topside
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chiefKP, Jun 6, 2002.
  1. chiefKP
    chiefKP Registered Member
    Mar 17, 2000
    16
    Pyongtaek, Korea
    Greetings from Korea!
    On my way to work this AM I was shocked to discover oil running out of the breather on the passenger side valve cover. It was a gusher! I probably blew out a quart in 5 miles.
    What could the problm be?
    I have an 84 K-5 4X4 with a 305/5.0 liter V8 and a manual 4-speed I affectionally refer to as "Yellow Fever".
    Thanks.....
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Possibly a drainback hole in the head has clogged and the valve cover is filling with oil. Pull the valve cover off and inspect it.
    Hope that helps!
  3. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Check your PVC valve. I had a J##p with a 401 in it that did the same thing once when the valve got stopped up.
